lubricating cams and also a gasket question
Old Mar 14, 2007 | 01:16 PM
nexgen91's Avatar
Default lubricating cams and also a gasket question
Putting my B16A head back together, I have been told I can use Oil to lube my cams and all when installing, Im trying to put my motor together and cant find engine assy lube any where here (in germany, language barrier sucks) would oil be ok, or should I order some lube and just put up with waiting? Also any clue where these gaskets go in the head?
Old Mar 14, 2007 | 03:07 PM
nexgen91's Avatar
Default Re: lubricating cams and also a gasket question (nexgen91)
bump
Old Mar 14, 2007 | 04:30 PM
DmcL's Avatar
as far as im aware oil will do fine.
any word on postage of those mudflaps? i may not need them but im assuming i will tho it woud be nice if this donor civic i should be getting has a full set on it.
Old Mar 14, 2007 | 05:26 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: (DmcL)
top left looks like exhaust manifold mid pipe gaskets, bottom left is thermostat gasket
Old Mar 15, 2007 | 02:25 PM
nexgen91's Avatar
Bump for more on the lubricating question.
Old Mar 15, 2007 | 03:10 PM
Heylookits shawn's Avatar
the thing about assembly lube is, you can grease it up and just let it sit for a while, and the lube will stick to it. with oil, you have to put everything together and get it going right away, because the oil will drip off
Old Mar 15, 2007 | 05:27 PM
kim_2_da_chee's Avatar
Default Re: lubricating cams and also a gasket question (Heylookits shawn)
If it will help, I just used normal motor oil when assembling my motor.
Gaskets: Those 4 in the bottom center looks like injector grommets
Old Mar 15, 2007 | 05:58 PM
gringo7718's Avatar
Default Re: lubricating cams and also a gasket question (kim_2_da_chee)
you can use motor oil and if you are really concerned, wait until you have everything ready, and add oil last. pour the oil all over the cams/head then put on the vavle cover and then start the car.
Old Mar 15, 2007 | 06:08 PM
Crx Jimmy's Avatar
Default Re: lubricating cams and also a gasket question (gringo7718)
As stated before oil is fine,Im assuming you are also using your old cams, if you were installing some new cams I would be more worried, but it should be fine if you plan on getting the engine going soon.
Old Mar 16, 2007 | 08:41 AM
nexgen91's Avatar
Default Re: lubricating cams and also a gasket question (Crx Jimmy)
yes i am just reinstalling my old cams. thanks for the help thats what I was looking for. I plan on starting it up right after I get it back together.
Cameronphelan
Honda Civic (2001 - 2005)
May 29, 2015 10:23 AM
EFSedanMan
Mar 6, 2010 12:58 PM
brandonEM1
Apr 10, 2009 05:01 AM
brian3676
Jan 10, 2006 09:12 AM
boosted_TSi
Feb 1, 2005 07:08 AM
