96 h22 injector question
i was wondering if there is a difference between 96 obd2 345 injectors and the 92-95 obd1 injectors. i was curious since the 96 prelude is obd2 does it have different clips than its predecesor. i want to know if i could use the obd2 96' 345's in 98 obd2
yeah i know they are peak and hold but do you know if the have the same clips as the 97+ h22's? i basically want to run larger injectors without the hassle of wiring in obd1 clips. i have to return the car to stock specs for inspection so i dont want to solder in clips. a resistor box is easier to remove as needed.
Oh? The '96 OBD2 has a resistor box?? I would have thought since it was OBD2 it didn't have a box and that the injectors weren't Peak & Hold..
Oh well.. More info!
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91preyludesi »</TD></TR><TR><TD CLASS="quote">i know you need a resistor box since they are peak and hold not saturated. but are the injector clips themselves actually different than 97+?? im curious since they both are obd 2 </TD></TR></TABLE>
i have a 96 prelude. and the clips r the same as 92-95 obd1 injectors. i guess they changed them in 97.
