Engine Check LIght problem? :S
Old Mar 14, 2007 | 11:39 AM
lilchin's Avatar
Default Engine Check LIght problem? :S
I have a 91 crx with a b16a engine, the problem is the engine check light. When i switch the car on and its warming up the light is off. Then once the engine has warmed up the engine check light turns on?? Has any one got any ideas?? Also my speedo and techo don't work??
Old Mar 14, 2007 | 11:46 AM
KFBhonda's Avatar
Default Re: Engine Check LIght problem? :S (lilchin)
look at the ECU in the pass. floorboard. it will blink a red light telling you the check engine light trouble code.
READ THE FAQ
*and i am guessing VSS since your tech no worky
Old Mar 14, 2007 | 11:53 AM
wiZCo's Avatar
Stouts 'n' Scotch
Could be an O2 sensor issue as well. Only way to find out is to read the codes, then you know exactly what to fix .
Old Mar 14, 2007 | 11:56 AM
lilchin's Avatar
Default Re: (wiZCo)
Thats the thing i've checked the ecu and its puttin out no codes
Old Mar 14, 2007 | 11:59 AM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: (lilchin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lilchin &raquo;</TD></TR><TR><TD CLASS="quote">Thats the thing i've checked the ecu and its puttin out no codes </TD></TR></TABLE>
Well, it is if you get a CEL. Is the light not blinking on it? If that's the case, you may want to check it with a known working ECU (I'm not sure if you can just replace the bulb).
Old Mar 14, 2007 | 02:10 PM
baboracus's Avatar
Default Re: (wiZCo)
im getting 8 flashes. ill try to find the FAQ.
TeamSumner
Sep 29, 2014 05:14 AM
sublimenerd
Oct 19, 2006 09:11 PM
Defiant1999
Jun 3, 2003 10:41 AM
EKtypeRhaTcH
May 2, 2003 08:03 PM
NastyGSR
Oct 8, 2002 11:41 PM
