Injector help please!
Old Mar 14, 2007 | 11:38 AM
frstbte14's Avatar
Default Injector help please!
I have a H22A1 that recently blew a hole in my engine block. I now am replacing it with a H23A, and my question is how do you know whether your injectors are low impedence or high impedence. I am unsure of the year of my engine, I assume it is an OBD2 so there is a chance I may not need the resistor box. Please help!
Old Mar 14, 2007 | 01:00 PM
Speedra500's Avatar
Default Re: Injector help please! (frstbte14)
if you have an h22a1 is has a resistor box and if you got an h23 it will use a resistor box too as long as they both use factory injectors
Old Mar 14, 2007 | 01:05 PM
genocide43110's Avatar
http://www.robietherobot.com/s...e.htm
Do you have a 4th gen? If you do then you are ok.
1992-'96 Prelude Non-VTEC Peak and Hold 240cc
1992-'96 Prelude VTEC Peak and Hold 345cc
1997-up Prelude VTEC H22 Saturated 280cc
Old Mar 14, 2007 | 01:10 PM
117's Avatar
117
Just measure the impedance across the injector. 3-4 Ohms = P&H, 12 Ohms = Saturated.
Old Mar 15, 2007 | 08:55 AM
frstbte14's Avatar
okay, im sorry i should have elaborated. i put an american spec 95' h22a1 dohc vtec in my 93 civic. i blew a piston out the block. now i am replacing it with a j-spec h23a dohc vtec, unsure of the yeah, and unsure if it is obd1 or obd2.
Old Mar 16, 2007 | 07:35 AM
frstbte14's Avatar
bump. please!?
Old Mar 16, 2007 | 10:37 AM
1GPlusSH's Avatar
I hope you got a obdII wiring harness...
I wish I knew just by looking at a motor if it is obdI or II. Have you thought about using the h22's injectors and keeping the resistor box....I don't know which one I'd do. I'm just throwing ideas out there.
Old Mar 16, 2007 | 11:05 AM
pinecone's Avatar
Default Re: Injector help please! (1GPlusSH)
The 95 is OBD1, the 96 and above is OBD2.
Old Mar 16, 2007 | 11:58 AM
frstbte14's Avatar
Default Re: Injector help please! (pinecone)
well i want to use the injectors that came with the engine, at which point i am unsure of what they are. obd2 were 265's high impedence. that means i can use my gsr ecu, and not throw an injector code. but the older ones, the ones that i just pulled out of my old engine, were low impendence, and had a higher flow rate, 345. should i not wire in the resistor box and use the 265 on my p13, or should i wire in the resistor box with the 345s?
Old Mar 16, 2007 | 02:12 PM
1GPlusSH's Avatar
265? Weren't the stockers for the obdII 290? How far is that going to push those 265s? I'm a noob as far as duty cycle goes. I've never looked into it.
If you have all the sensors and wiring for obdII and you're not going to do anything else with the car, I'd keep it obdII. Otherwise, spend the time now, and put that resistor box in with the 345s....make sure you tune those.
Old Mar 16, 2007 | 05:09 PM
preludefien
Guest
Posts: n/a
i have the stock injectors you need if you want to get em...shoot me an offer..
Prudz_lude
Oct 15, 2014 06:44 AM
racekar
Sep 30, 2004 03:07 PM
ensracer
Mar 6, 2004 03:11 PM
thehondaguru
Feb 14, 2004 04:32 AM
skilzz
Nov 5, 2002 10:16 AM
