Idle Issues...help!
i have a 1989 honda civic si with the stock d16a6 and i am getting a pulsating idle. it will idle at 1500 then drop to 800rpm then go back up to 1500 and drop again and repeat constantly. its really annoying. i replaced the IAC motor with one from an integra(will that work?) anyway it looked identical and fit perfect so i threw it in ....i am still getting the bad idle....is this a vacuum leak of some sort? anybody have this happen to them?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bejita »</TD></TR><TR><TD CLASS="quote">Your coolant level is probably low or needs to be purged. Sounds wierd but that causes a surging idle.</TD></TR></TABLE>
Do this if you're not getting a CEL, pretty common problem. I'd say it could still be a bad IACV but you've changed that. A vacuum leak would simply cause a high idle situation.
Civic Racer X 7
Jul 23, 2003 07:19 AM
Pele
Feb 9, 2003 01:01 AM
