Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
06 Si slight clicking in clutch
Old Mar 14, 2007 | 06:01 AM
mikseries's Avatar
Default 06 Si slight clicking in clutch
Don't really notice it in shifting while driving, but if i sit there in neutral and push the clutch in, i feel the slightest two little clicks. please no smart @$$ replies like, "don't sit in neutral and push the clutch in"
Old Mar 14, 2007 | 08:13 AM
originalg00kster's Avatar
Default Re: 06 Si slight clicking in clutch (mikseries)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikseries &raquo;</TD></TR><TR><TD CLASS="quote">Don't really notice it in shifting while driving, but if i sit there in neutral and push the clutch in, i feel the slightest two little clicks. please no smart @$$ replies like, "don't sit in neutral and push the clutch in"</TD></TR></TABLE>
your telling us to give you no smart replies..but yet your doing the same thing?
Old Mar 14, 2007 | 09:15 AM
elohel's Avatar
[Speculation] Maybe the clicking is just unlocking something in the car that can only be done when the clutch is depressed? An example of this is on the Auto civics. When you depress the brake, and this is barely audible unless your head is right near the shifter, you can hear a tiny, tiny click that is letting you push the button in to shift out of park.
Then again, I can see myself being totally wrong on this since you prolly shouldn't be hearing a clicking noise from the seat when you depress the clutch.
Old Mar 16, 2007 | 07:27 AM
Tzang's Avatar
Nice catch...I get that in my 07 Si Sedan too...but I just ignore it...as long as it doesn't do anything serious to my car...you can berely tell unless you really feel for it...
Old Mar 16, 2007 | 08:00 AM
cnyej1's Avatar
Default Re: 06 Si slight clicking in clutch (Tzang)
.......runs out to car to listen for the click.........
Old Mar 16, 2007 | 09:16 AM
Kiwibird83's Avatar
Reigning GDD Queen
Most likely the auto adjuster on the clutch pedal. Its just adjusting each time you push in the clutch.
Old Mar 17, 2007 | 03:35 PM
mikseries's Avatar
Default Re: 06 Si slight clicking in clutch (originalg00kster)
? i missed that
Old Mar 30, 2007 | 08:59 PM
Nighthawk R18's Avatar
i have the same clicks in my LX
it clicks midway when depressing the clutch, and right before it hits the floor.
only notice it when my fone rings and my music is down.
Old Mar 31, 2007 | 07:47 AM
supersi06's Avatar
Default Re: (Nighthawk R18)
I was just about to say the samething, except I have the 06.
This isn't really like a clicking noice, but more like a spring. Like when you push a spring together.
Not good. My A/C went out, now this?
Old May 21, 2007 | 11:06 AM
Napoleon's Avatar
my 2007DXG does the same thing.
I looked into it..........
On my clutch pedal there is an assembly attached to a single wire.
When you depress the clutch, a sping-loaded mechanism allows for the wire to contact the metal of the assembly.
The noise is actually being caused by metal on metal contact.
I have no idea what this assembly does. I actually removed it from mine with a single nut. At first I thought it might be connected to the ignition kill switch to make sure that you have the clutch in when you start the car.
I have no idea what it does, but i removed mine and the noise is gone.
IF ANYONE KNOWS WHAT THE HELL IT IS, PLEASE LET ME KNOW.
I'M SURE THEY PUT IT THERE FOR A REASON.
Old May 21, 2007 | 01:52 PM
Default Re: 06 Si slight clicking in clutch (Napoleon)
eh ?! ?!!
pic would be nice. please and thank you
Old May 21, 2007 | 06:00 PM
CrisEK's Avatar
it probably ur nuetral safety switch
imadigitalgod
11
Nov 18, 2006 11:27 PM
ic89
Oct 17, 2006 11:59 AM
JoNNiE
May 23, 2005 06:42 PM
91B17A_Teggy
Aug 26, 2004 04:52 PM
AspectIndustries
Jan 5, 2004 07:49 AM
