need help!!!
Old Mar 13, 2007 | 10:06 PM
husslinn86's Avatar
Default need help!!!
i have a 92 civic hb dx 1.5 sohc non v-tec and i was wondering if i get the d16z6 will it bolt right up to my stock tranny or will i have to change anything
Old Mar 13, 2007 | 11:15 PM
sleeperrex's Avatar
Default Re: need help!!! (husslinn86)
yes it will bolt right up
Old Mar 13, 2007 | 11:45 PM
husslinn86's Avatar
so i can use my stock clutch????
Old Mar 13, 2007 | 11:47 PM
sleeperrex's Avatar
Default Re: (husslinn86)
yes... clutch, flywheel, you can use it all
Old Mar 14, 2007 | 01:57 AM
KnightX's Avatar
all D motor and tranny should bolt right up
Old Mar 14, 2007 | 06:05 AM
ek4_b16a's Avatar
Default Re: (KnightX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KnightX &raquo;</TD></TR><TR><TD CLASS="quote">all D motor and tranny should bolt right up</TD></TR></TABLE>
not true...only the ones from 92-00 will, for hydro cars...
Old Mar 14, 2007 | 06:11 AM
twinj's Avatar
^^agreed
forgot about that. I only think of cable and hydro for the B's.
Old Mar 14, 2007 | 06:22 AM
instructor74's Avatar
As the others have said yes it will. However the gearing in your dx trans will be different then what came with that motor in an ex/si. If you can find one get your hands on the S20-B000 that is the ex/si trans it has shorter gearing in it. You dx should have a S20-A000 look for a small stamp on the trans case near the oil fill hole
Old Mar 14, 2007 | 11:02 AM
husslinn86's Avatar
Default Re: need help!!! (instructor74)
thanks for the info where can i get a d16z6 with low miles????
Old Mar 14, 2007 | 11:09 AM
BLUIZE256's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by husslinn86 &raquo;</TD></TR><TR><TD CLASS="quote">thanks for the info where can i get a d16z6 with low miles????
try checkin the H-T marketplace when your trial is up... you can also check eBAY, craigslist, etc.
or go to google and type in "D16Z6 cheap" and i'm sure you'll find a few web-sites sellin them
TravisCadello
Nov 19, 2008 08:05 AM
xak98x
Jul 23, 2007 11:20 AM
pulehu
Jul 9, 2006 01:30 AM
FERIOkid
Aug 1, 2004 04:00 PM
minorthreat
Mar 30, 2003 11:45 PM
