Help with spark plug choice for a high compression motor
Okay guys, my mechanic is putting my head and block back together. I need to know what plug to run in a motor with 12.1:1 compression (CTR pistons), and Jun 3's
i would worry about breaking in the rings/bearings properly first
stock should be fine - i've tried plugs one temp range cooler and they run like crap until the motor warms up
no need for #8
NGK PFR7G-11 or BKR7EVX11
sgt - what's the difference between a VX high perf platnium and the PF platnium???
I thought the B plugs were all copper?
I'm wondering would copper or platinum be a better choice for performance? From what I know, copper conducts better but doesn't last as long. Platinum I thought was used mainly for it's longevity. However we are not the type to wait until the 60k interval to change plugs anyway so why not use copper for better conductivity?
Say for a tuned B18C5 motor with stock internals, would the NGK BKR6EVX11 be a good replacement? What about the full copper V-type BKR6E-11? I'm also concerned because laser tip plugs aren't gappable and if I order some from sparkplugs.com and the gaps happen to be off I have to go through the hassle of returning and waiting etc.
So any further insight on the copper vs. platinum and v-type vs. laser tip? I did a forum search, and came up pretty empty.
Champs32
Nov 26, 2008 12:19 PM
slacks
Feb 22, 2008 07:25 PM
Quitripin
16
Aug 18, 2004 09:20 PM
