Setting Timing on B16
Old Mar 13, 2007 | 08:16 PM
Zaakro's Avatar
Default Setting Timing on B16
Ok i put the cams at up and the 2 lines match up and I put it at TDC, I set it to the middle line. Now i the crank shaft counterclockwise 3 teeth and tighten the tensioner bolt.
Ok when i do that now the crank shaft is set on the 4th line. is that right or am I doing it the wrong way?
ok you see the group of 3 lines and it is set on the line far above that.
Modified by Zaakro at 9:47 PM 3/13/2007
Old Mar 13, 2007 | 08:44 PM
Jarrat's Avatar
Default Re: Setting Timing on B16 (Zaakro)
You want to be moving away from the three timing marks.
Old Mar 13, 2007 | 08:46 PM
Zaakro's Avatar
Default Re: Setting Timing on B16 (Jarrat)
Oh i meant counter clockwise.
Old Mar 14, 2007 | 03:05 PM
Zaakro's Avatar
bump
is that the correct spot or and i doing it wrong?
Old Mar 14, 2007 | 04:22 PM
civicjdmb16a's Avatar
that sinlge line is your TDC mark. the three notches are 14 16 18 degress after top dead center. as long as your single line matches the cover and your cams are both UP then your good
Old Mar 14, 2007 | 05:18 PM
Zaakro's Avatar
Default Re: Setting Timing on B16 (civicjdmb16a)
thanks that helped out alot
Old Mar 29, 2007 | 07:08 PM
crxpwr1's Avatar
very good thread going to help me out tomorrow thank you ....never even knew there was teeth there...very good info...no wonder why my car wouldnt start today
shesinmyroom
11
Jun 7, 2012 08:07 PM
young geezer
May 18, 2009 10:29 PM
ekpilot
Jan 22, 2009 07:42 PM
lv6l
Nov 17, 2005 12:33 PM
ScottEK
13
Sep 25, 2002 08:23 PM
