wiring help!!!
Old Mar 13, 2007 | 07:54 PM
b16a2hatch's Avatar
Default wiring help!!!
alright here is my problem... i am swapping a 2000 civic si b16 into my 90 hatch.. and i need to kno how to get the obd2 ecu to run the rest of my car not including the motor. if anyone can help i would really appreciate it.
Old Mar 13, 2007 | 08:57 PM
Jarrat's Avatar
Default Re: wiring help!!! (b16a2hatch)
Your gonna need the complete obd2 harness, including the complete ignition system.
Old Mar 13, 2007 | 09:01 PM
Slurp56's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16a2hatch &raquo;</TD></TR><TR><TD CLASS="quote">alright here is my problem... i am swapping a 2000 civic si b16 into my 90 hatch.. and i need to kno how to get the obd2 ecu to run the rest of my car not including the motor. if anyone can help i would really appreciate it.</TD></TR></TABLE>
What else do you need it to run? ECU stands for Engine Control Unit. I guess I am confused as what else you need it to do.
Old Mar 14, 2007 | 04:41 AM
b16a2hatch's Avatar
Default Re: wiring help!!! (Slurp56)
i need it to run the rest of the car as in the dash and ignition... i have the harness to run the motor.
Old Mar 14, 2007 | 08:31 AM
b16a2hatch's Avatar
i still have the other car (wrecked 00 si) do i need to get anything else off of it to get it to work??
Old Mar 14, 2007 | 08:52 AM
dbiker207's Avatar
your doing it the hard way, convert it to obd1(preferred) or obd0
Old Mar 14, 2007 | 08:56 AM
VtecSyndrome's Avatar
Default Re: wiring help!!! (dbiker207)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dbiker207 &raquo;</TD></TR><TR><TD CLASS="quote">your doing it the hard way, convert it to obd1(preferred) or obd0</TD></TR></TABLE>
x2, just look up Rywire since they make it soo easy to do this kind of stuff if you aren't good with wiring (hince why you posted this question).
I too say go OBD1, much easier and benificial for power gains.
Old Mar 14, 2007 | 12:15 PM
Slurp56's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16a2hatch &raquo;</TD></TR><TR><TD CLASS="quote">i need it to run the rest of the car as in the dash and ignition... i have the harness to run the motor.</TD></TR></TABLE>
I'm guessing you are planning to use the wire harness from the 00 Civic Si, correct? Dont.
Use the existing wire harness off of your old motor. Modify it to fit the B16 and then you'll need to swap the connectors at the ECU to OBD2 connectors. You'll also need to run several new wires if you plan to run the OBD2 ECU and add some emissions components to your car. It can be done, I've done it before, but realisitcally, convert to OBD1 and save yourself some time.
Old Mar 14, 2007 | 12:35 PM
Fobtions's Avatar
obd2 ecu also runs a tank sensor that u cannot use in a 90 hatch.
convert to 4 injector if u arent already, and preferably use a obd1 p30 ecu
Eddy562
16
Oct 22, 2011 03:47 PM
Scotty Dosent Know
13
Oct 11, 2005 08:46 AM
jdmcivic1999
Oct 2, 2005 10:59 PM
ragnampizer
May 8, 2005 08:59 AM
jdm420da6
Feb 25, 2004 04:02 AM
