please help with my rumbling front end
Old Mar 13, 2007 | 07:31 PM
93dabeast's Avatar
Default please help with my rumbling front end
i have a harsh rumble in my front end on my eg. my ftont end rumbles hard when accelerating straight and when i turn right but when i go left it stops. all the parts in my front end are new... axles, ball joints, tie rods, upper control arms, etc. everything it tight. can someone please help??? is it a bad differential? my half shaft has a little bit of play could that be the problem?
Old Mar 13, 2007 | 08:08 PM
sleeperrex's Avatar
Default Re: please help with my rumbling front end (93dabeast)
wheel bearing?
or unbalanced tires?
Old Mar 13, 2007 | 08:15 PM
EG_LS's Avatar
Default Re: please help with my rumbling front end (sleeperrex)
If it was the wheel bearings then it would be making a popping noice when you turn.Maybe your axels? do you have aftermarket motor mounts?
Old Mar 14, 2007 | 04:11 AM
93dabeast's Avatar
i have stock integra motor mounts. and i just replaced my axles. it was doing this with the old axles and i thought this would fix the problem. there is no popping sound just one hell of alot of rumbling. it is only when i accelerate going straight and at all times when going right. when i go left it smoothes out and drives normal. my half shaft seemed to have play in it (back and forth not in and out) could that be whats causing this? stupid problems like this are real frustrating
Bigdog1456
Honda CR-V & Element
Jun 21, 2013 09:55 AM
hondaskerp2000
Apr 20, 2013 11:25 AM
Carvedtop
12
Jan 23, 2013 05:20 PM
93dabeast
Suspension & Brakes
Mar 14, 2007 09:44 AM
Boudreau
Aug 15, 2006 02:48 PM
