Checking my bore: Is this gauge ok?
Old Mar 13, 2007 | 07:18 PM
Tippyman's Avatar
Default Checking my bore: Is this gauge ok?
http://www.harborfreight.com/c...94873
Are the anvil sizes ok for checking the bore of my A6? (75mm)
Is it a good buy all in all? I've never bought engine machining tools before...
Old Mar 13, 2007 | 09:15 PM
:Josh:'s Avatar
Default Re: Checking my bore: Is this gauge ok? (Tippyman)
You'd probably be better off using a pair of good vernier calipers than that. A good, accurate dial bore gauge costs a little more than $99!
Old Mar 13, 2007 | 09:20 PM
thomas@LPS's Avatar
that is the bore gauge that i used to measure my z6 75.5mm and my tuner has used to measure multiple blocks. that is much more accurate than vernier calipers. the bore gauge is accurate to +/-.0002" and calipers are only acurate +/_.001".
Old Mar 14, 2007 | 06:55 PM
Tippyman's Avatar
Default Re: (civic_ex_95)
All I want to do is see if it's the same all the way down.
Old Mar 14, 2007 | 11:05 PM
V-SPEC 1's Avatar
Default Re: (Tippyman)
You'll be alright w/ that.
Old Mar 19, 2007 | 05:43 PM
:Josh:'s Avatar
Default Re: (V-SPEC 1)
How will you know if they are the same if you have .0004" variation allowed in your dial bore gauge?
Old Mar 19, 2007 | 05:57 PM
awdgsx96's Avatar
Default Re: (:Josh:)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by :Josh: &raquo;</TD></TR><TR><TD CLASS="quote">How will you know if they are the same if you have .0004" variation allowed in your dial bore gauge?</TD></TR></TABLE>
That's not the point. Well I understand what you mean by being accurate for a reading. But even if it is off, it will still be off by say the .0004'' the whole way down, if there is an inconsistency, it will show it.
cnydc2
20
Jun 10, 2009 12:25 PM
Civicman86
Sep 23, 2008 04:49 PM
b20vtech
Apr 16, 2008 08:09 AM
jetlude
Jan 2, 2008 05:50 PM
MooreBoost
Jan 11, 2005 07:46 PM
