Troubleshooting code?
i popped my ecu and it gave me a code of 6 fast check engine light pauses, and 7 hard pause check engine lights..whats that mean..it popped up in the same order as i wrote it!..im comfuzed on what that code is
it should be hard pauses first, then should be fast lights. If this is so, means its throwing a code 76...
hard pauses signifies multiples of 10, fast lights signifies multiples of 1.
I.E....
1....2.....3.....4
that means 40, now 1.2.3.4 that means 4. You understand?
I.E....
1....2.....3.....4
and just so ya know...
there is no code 76...
but there is a code 67...
which is a code for a Catalytic Converter. But the way you described it, it should be a code 76
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djcue_530 »</TD></TR><TR><TD CLASS="quote">i popped my ecu and it gave me a code of 6 fast check engine light pauses, and 7 hard pause check engine lights..whats that mean..it popped up in the same order as i wrote it!..im comfuzed on what that code is</TD></TR></TABLE>
is your cat punched out. my car used to throw that code when it was obd2. after i punched out the cat.
wuhungsixxx
Jul 15, 2002 03:45 PM
