dragstrip tips
Old May 23, 2002 | 04:23 AM
ITR #1202's Avatar
Default dragstrip tips
hey well I am going to a local dragstrip (1/8) tonight and I was wondering if I
could get any tips on makeing some good runs the best I have had so far is a 9.64@75.50 my mods are a AEM CAI I also have new NGK plugs & wires and a
DC sports shifter. Will taking off the powersteering belt help any? thank for any
info .
Old May 23, 2002 | 05:00 AM
Digital-R's Avatar
Default Re: dragstrip tips (ITR #1202)
info .
PS belt is good for 3-4 whp.
MPH's Avatar
MPH
New User
P/s belt = 2/10's
Old May 23, 2002 | 10:03 AM
ITR #1202's Avatar
Default Re: dragstrip tips (MPH)
anymore tips? anybody
Old May 23, 2002 | 10:08 AM
EagleR's Avatar
do you know how to launch right, I'm no drag hag but it takes practice....ask one of the drag ****** for some tips there.....
Jody....road race **** who knows that out of every corner, and every green flag theres a drag race....
Old May 23, 2002 | 11:25 AM
t's Avatar
t
Remove all the extra weights: spare tire, jack/tools, rear seats, pass. seat, cargo cover, mats, etc...
Make sure your gas is near low. Play with tire pressures.
[Modified by t, 12:27 PM 5/23/2002]
Old May 23, 2002 | 11:30 AM
sackdz's Avatar
Default Re: dragstrip tips (t)
Fold in side mirrors
Run heater full blast right before run
Remove passenger corner lens for more air to intake
Old May 23, 2002 | 11:33 AM
RTW DC2R's Avatar
Default Re: dragstrip tips (sackdz)
NAWWWWWWWWWWWWWWS
Old May 23, 2002 | 11:41 AM
FAST94GSR's Avatar
New User
Default Re: dragstrip tips (RTW DC2)
fold the mirrors in??? come on man..
pump up your rear tires to 42psi.
lower fronts to 18-20psi. don't know if you got slicks or radials or what..
ice down the intake between runs. let that bitch get nice and cold. push car up to line then fire her up, do burnout and go.
shallow stage and leave on last amber and sidestep that clutch hard.
Old May 23, 2002 | 11:44 AM
RTW DC2R's Avatar
Default Re: dragstrip tips (FAST94GSR)
burnout depends on what kind of tires you are using, correct? Ive heard not to do a burnout if you are on you regular street tires. And from my experience, it seems if I run too low air pressure, it give a really soft, slippery feel and not the best launch. If you are on slicks, then light them bad boys up.
Old May 23, 2002 | 12:13 PM
PM-Performance's Avatar
what you mean about the mirros? i fold mine in all the time . . . anytihng helps man .
i take out my lense where my cai is , no ps. no ac, no seats, no spare tire, adv timing , lower pressure in tires, etcetcetc.
Old May 23, 2002 | 12:17 PM
baonest's Avatar
Default Re: dragstrip tips (itr206)
go in reverse!!!!!!!!
Old May 23, 2002 | 12:33 PM
JDM 007's Avatar
Default Re: dragstrip tips (baonest)
What about your RPM at launch? I'm sure it's different for each car depending on mods but I have a hondata 4 and have the 2 stage rev limiter! What RPM do you guys recomend launching at. I also have CAI and Apexi Dunk cat back.
Any help is greatly appreciated....
vadeR
Old May 23, 2002 | 02:12 PM
t's Avatar
t
Default Re: dragstrip tips (vadeR)
It all depends on your power and weight of your car and of course if your on slicks or street tires(and than there is pressure and how sticky your tires are.)
With slicks, probably 6000-8000rpm launch
street tires, probably 3500-5000rpm(feathering a lot)
Old May 23, 2002 | 02:41 PM
on slicks the highest ive taken is 7000 off the line . . on aftermarket clutch of course. im gonan step up a bit higher when i wire my 2 step up
on street tires and stock clutch , i only raced one race on st tires and dropped it at 4000-4500 or so and it kinda worked for me .
dont launch above 5500 or so on a stock clutch you will kill it quick . i have exp in that ,
Old May 23, 2002 | 02:44 PM
reefer_bob's Avatar
He's only doing an 1/8th mile. I don't think the mirrors are gonna do that much.
Don't let the engine get too cold, else your VTEC won't engage...
Old May 23, 2002 | 02:47 PM
t's Avatar
t
Yes, I forgot about that; The stock clutch might not hold depending on your power.
Old May 24, 2002 | 09:10 AM
ITR #1202's Avatar
well I ran last night here's how I did. I guess its OK the only mod I have is a AEM
CAI.
RT-.661
60ft-2.317
330ft-6.332
594ft-9.004
1/8-9.587
MPH-77.18
Old May 24, 2002 | 10:21 AM
ITR #1202's Avatar
what does a stock R in the 1/8?
Old May 24, 2002 | 10:35 AM
RTW DC2R's Avatar
whats an average 60ft time for a relatively stock R on street tires?
Old May 24, 2002 | 10:37 AM
IGGY's Avatar
Hardcore.
shadydb7
Nov 21, 2007 01:44 PM
hb_guy
Jun 11, 2007 01:40 PM
White92Hatch
Aug 30, 2004 02:01 PM
