h2b axle problems
Old Mar 13, 2007 | 01:52 PM
dohcteg's Avatar
Default h2b axle problems
Sup guys. I have a b16 Ek coupe for a while now and after a while of driving it, im not feeling it anymore. I dynoed back like few weeks ago (feb 22 i think) it made 177 hub hp on a dynapack 2000 dynoed at church. Anyways, I've just realized that my b16 isnt the fastest thing in the wolrd now. I was thinking of doing the h2b swap. The question is, since the h22 will be using a b-series tranny, does that means the axle will be lined correctly as in straight instead of angle like any other complete h22 swap? In fact, thats the reason y i didn't go with the h22 complete swap in the 1st place because many people have had problems with axle snapping off or what not. Please correct me if im wrong. Info/opinion/comments/name calling welcome!
Old Mar 13, 2007 | 05:56 PM
dohcteg's Avatar
Default Re: h2b axle problems (dohcteg)
No one have any info on this?
Old Mar 13, 2007 | 05:59 PM
fmrprojects's Avatar
just change out your block to a type r or a lsvtec or sometrhing
Old Mar 13, 2007 | 09:45 PM
dohcteg's Avatar
Default Re: h2b axle problems (fmrprojects)
Anyone know of a super good shop around socal area that will be able to do h2b swap into ek for reasonable price? thanks
Old Mar 14, 2007 | 09:51 AM
skunked's Avatar
The QSD H2B kit keeps the B tranny in the OEM location therefore the stock axles, shift linkage and mounts from the B series are still used.
All those H22 axle issues go away.
Old Mar 14, 2007 | 10:06 AM
DailyDrivenEJ1's Avatar
Might want to call Evolution Industries they will hook you up.
Old Mar 14, 2007 | 11:41 AM
skunked's Avatar
Default Re: (DailyDrivenEJ1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DailyDrivenEJ1 &raquo;</TD></TR><TR><TD CLASS="quote">Might want to call Evolution Industries they will hook you up.</TD></TR></TABLE>
Your like a broken record. Do you even own a kit or just nutt swingin?
Old Mar 14, 2007 | 12:48 PM
I own a h2b in a ej1 evolution hooked me up with everything that i needed for the h2b and they were local
Old Mar 14, 2007 | 02:35 PM
high_revs's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DailyDrivenEJ1 &raquo;</TD></TR><TR><TD CLASS="quote">I own a h2b in a ej1 evolution hooked me up with everything that i needed for the h2b and they were local </TD></TR></TABLE>
so does QSD....both kits come with everything to make it work...
h2b will maintain stock b series axle angles so you would use b series axles and have no issues..
Old Mar 16, 2007 | 12:24 AM
What would be a good setting to put on the cam gears for the H22
Old Mar 16, 2007 | 07:54 AM
high_revs's Avatar
only dyno tuning would tell...
Old Mar 16, 2007 | 07:15 PM
yea ima take it soon but i was wondering just for now right now it feels good on the low end but sucks on high end
Old Mar 17, 2007 | 11:29 PM
dohcteg's Avatar
Default Re: h2b axle problems (skunked)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunked &raquo;</TD></TR><TR><TD CLASS="quote">The QSD H2B kit keeps the B tranny in the OEM location therefore the stock axles, shift linkage and mounts from the B series are still used.
THanks alot thats the EXACT answer i was looking for! Im really interested in this swap BUT just did a lil more research and the downside is...no1 has a kit for an EK yet..... I might have to wait on this...
Old Mar 18, 2007 | 06:04 AM
high_revs's Avatar
just fab your own driver side mount..
Mfoehrkolb
Sep 5, 2012 09:45 PM
93h22da
Transmission & Drivetrain
Dec 19, 2011 10:22 PM
tr0n9h
Oct 5, 2007 12:43 PM
