FUSE BOX DIAGRAM FOR A 99 CIVIC
hey just wondering if anyone knows where i can get a fuse box diagram online. i wanna see if anything's wrong with my engine but the check engine light isnt on. there is obviously something wrong with it the way it idles weird and stutters every now and then. i went to autozone to see if they could run the ecu to see if there is anything wrong. they said that if the light doesnt come on then it wont read anything. Here is the thing, it wont even come on when you start the car like it should, so i was wondering if it could be a fuse or something that causes it to not come on. if nobody knows where to get one then do you know which fuse it might be?
I believe that the CEL is on the same circuit as the rest of the instruments (or at lest the rest of the warning lamps), so it's doubtful that the problem is a fuse. You can try removing the cluster to check if there's a problem with the bulb itself.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by munkyboy111 »</TD></TR><TR><TD CLASS="quote">bump</TD></TR></TABLE>
Did you read my post?
If you still want the fuse diagrams, I found these with a quick search (hint, hint).
https://honda-tech.com/zerothread?id=1790114
https://honda-tech.com/zerothread?id=1854249
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by super-hatch »</TD></TR><TR><TD CLASS="quote">pm me I will send u the whole shop manual for 96-00</TD></TR></TABLE>
pm'ed
pm'ed
Keizer
43
Jul 29, 2013 01:16 PM
