worked euro R injector ports (are they good enough??) (intake manifold type s port)
Old Mar 13, 2007 | 01:05 PM
Bense's Avatar
Default worked euro R injector ports (are they good enough??) (intake manifold type s port)
Lemme know what you guys think:
here they are unmodified:
i dremeled them some:
here's the injectors that i'll be using
and heres the stock euro manifold:
Old Mar 13, 2007 | 01:56 PM
98vtec's Avatar
moderator emeritus
Default Re: worked euro R injector ports (Bense)
that looks good. As long as you can keep the fuel from puddling, you should be good to go with that
Old Mar 13, 2007 | 02:36 PM
prelittlelude's Avatar
I went MUCH deeper, I made the injectors sit the way the sit in an OEM h22 intake mani. I also matched to the gasket
You may want to find out the angle of the spray pattern of your injectors.. The best advice i can offer is compare it too the stock h22 intake mani. When i bought my euro mani it came with a set of euro R injectors and they also sat much farther out, very similar to the way stock 345cc h22 injectors sit in the stock 2 stage mani
Old Mar 13, 2007 | 03:15 PM
Bense's Avatar
That's kind of what i figured. I think the next step is to find the "bore" size of the stock manifold and drill the euro manifold out to the proper size.
arg, this manifold sucks. Pun intended
Bense
Mar 14, 2007 02:18 PM
Vincent.
10
Aug 17, 2004 10:44 AM
Marauder
86
Aug 22, 2003 08:29 AM
TurboB18C1
Oct 9, 2002 10:56 AM
austrian type-R
Oct 3, 2002 09:43 AM
