vafc2 or a hondata set up? lude running rich, want to maximize performance on a stock lude searched.
Old Mar 13, 2007 | 09:59 AM
businessmanph's Avatar
Default vafc2 or a hondata set up? lude running rich, want to maximize performance on a stock lude searched.
searched prelude FAQ
The reason why I want to get a system for my car is because it is running factory rich and I’m getting a large quantity of black soot on the rear end of my car. I would also like to get it tuned to maximize performance.
My prelude sh is completely stock with the exception of a cai and I plan to keep it stock. My thoughts are that hondata s300 would be over doing it but it has timing adjustment options and it’s about 300 more dollars compared to a vafc.
What should I get for a stock set up, vafc, Hondata s100, s200, or s300?
Thank you for your time
Old Mar 13, 2007 | 10:10 AM
A Blue Lude's Avatar
Default Re: vafc2 or a hondata set up? lude running rich, want to maximize performance on a stock lude searc
You'd lose ATTS with anything that replaces your stock ECU. So you'll probably want to stick with an AFC.
Old Mar 13, 2007 | 10:14 AM
98vtec's Avatar
moderator emeritus
try the emanage ultimate
Old Mar 14, 2007 | 10:13 AM
aite next question should i get vafc or a vafc2?
thanks
Old Mar 15, 2007 | 10:06 AM
nvm
http://www.highaltitudeimports....html
i guest i'll get the 2
Old Mar 15, 2007 | 05:39 PM
M@'s Avatar
M@
Man some newb is using my tradmarked u/n on that forum. Time to regulate.
edit: not a newb, Postwhorus Maximus
Old Mar 16, 2007 | 04:42 PM
alphajesse's Avatar
VAFC/VAFC2 not worth the money, if you want to keep the ATTS, Emanage Ultimate is the way to go.
However, your sooty bumper can likely be cured by getting a new primary O2 sensor and replacing the PCV valve (OEM only, Fram ones suck.)
Old Mar 26, 2007 | 04:45 AM
Default Re: (alphajesse)
is it really true that you lose atts when you use a vafc2? i didn't see that in the prelude faqs.
can i keep atts with hondata s300?
do i need to convert my 01 sh to obd1 if it isn't already to use s300?
searched but still confused. i wasted loot on the vafc2
Old Mar 26, 2007 | 04:51 AM
Speedra500's Avatar
Default Re: (businessmanph)
they were referring to the hondata when they said you would loose ATTS if you replace the factory ecu. VAFC will not affect ATTS
Old Mar 26, 2007 | 04:58 AM
PrecisionH23a's Avatar
vafc
Old Mar 26, 2007 | 05:07 AM
flyrod's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by businessmanph &raquo;</TD></TR><TR><TD CLASS="quote">I’m getting a large quantity of black soot on the rear end of my car.</TD></TR></TABLE>
Are you burning oil? How is the fuel economy (it could be your O2 sensor)? Stock H22 ECU's are usually only rich above 6k RPM at WOT. Do you do a lot of driving under these conditions? You could get a chipped P28 for a lot less than hondata (which requires a chipped P28 anyway).
Old Mar 26, 2007 | 07:19 AM
lude98SH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by businessmanph &raquo;</TD></TR><TR><TD CLASS="quote">is it really true that you lose atts when you use a vafc2? i didn't see that in the prelude faqs.
you loose atts with hondata
yes you need to convert to obd1 to use hondata
Im not sure about the vafc because i have heard nothing but bad things about them so i never really looked into them
Old Mar 27, 2007 | 10:07 PM
Default Re: (lude98SH)
what is so bad about the vafc2?
if you had a choice would you
A keep the lude sh stock or
B install vafc2 and get it tuned to lean out the fuel so it isn't running rich.
Old Mar 27, 2007 | 10:29 PM
how do i get all the carbon build up out of my exhaust
i know about spraying decarb into the intake but what else could i do?
i have Deep Creep made by sea foam, if i spray this **** into my intake do i need to change my oil?
Old Apr 6, 2007 | 03:29 PM
my dyno results (stock lude besides cai and aem pullies)
useful info on unhooking your battery when you have a vafc hooked up
http://www.superhonda.com/foru....html
where should i mount the vafc?
i was thinking about hiding it behind the dash somewhere
i have the bracket wedged between the air vent
where can i buy those trim brackets that allows the vafc to sit near the cigarette lighter
the trimming that i'm talking about is what is in this pix but it's cf
Modified by businessmanph at 7:47 PM 4/6/2007
Old Apr 6, 2007 | 03:44 PM
russlan44's Avatar
so u tuned the vtec controller, is it running better now, any gains from it?
Old Apr 6, 2007 | 03:52 PM
Default Re: (russlan44)
the guy said that it doesn't run nearly as rich as before. he also said i gained 50 hp in the upper mid range rpms. hopefully i won't get any more black soot on the *** of my car and i'll get better gas mileage.
Old Apr 6, 2007 | 07:03 PM
russlan44's Avatar
50hp? in upper mid range
Old Apr 6, 2007 | 09:15 PM
M@'s Avatar
M@
Why did your stock car have Vtec kick in at 6300rpm?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by businessmanph &raquo;</TD></TR><TR><TD CLASS="quote">my dyno results (stock lude besides cai and aem pullies)
Modified by businessmanph at 7:47 PM 4/6/2007</TD></TR></TABLE>
Old Apr 7, 2007 | 07:43 AM
i have no clue. when i drove it before i heard it kicked in at 5200-5300.
Old Apr 7, 2007 | 09:38 AM
alphajesse's Avatar
There's something fishy about that dyno plot.
No H22 will gain 50hp with a VAFC tune.
Old Apr 8, 2007 | 11:37 AM
prolly not 50 but a slight gain was a bonus for me since i got it for the sole purpose of leaning out my fuel
Old Apr 20, 2007 | 04:52 PM
how long is it suppose to take for all this black soot to burn off my exhaust pipe?
i already sprayed decarb into the intake and did seafoam in the gas tank
Old Apr 23, 2007 | 06:44 AM
you see where he put his v-1 unit
where can i find a one that would hold a vafc2?
Old Apr 23, 2007 | 11:37 AM
nonvteclude's Avatar
your probably going to have top make something or use the supplied bracket upside down.
sledgehammer
Feb 29, 2004 07:21 AM
jwaked
Nov 20, 2003 12:14 PM
Teal95Coupe
Apr 4, 2003 03:04 PM
Cow
Nov 20, 2002 12:06 PM
