Wheels, Tires, Brakes, and Suspension Wheel, Tire, Brake and Suspension Parts (Wheels, Tires, Coilovers, Lug Nuts, Camber Kits, Rim/Tire Tools)
TEIN PRODUCTS: DAMPERS, PILLOW BALL UPPER MOUNTS, HOOD DAMPERS
Old Mar 13, 2007 | 09:41 AM
CRG Motorsports's Avatar
Former Sponsor - Cancelled
Default TEIN PRODUCTS: DAMPERS, PILLOW BALL UPPER MOUNTS, HOOD DAMPERS
<U>TEIN TYPE BASIC DAMPER:</U> PM FOR PRICE!!!
TEIN Type BASIC damper is for the driver that is seeking high performance with a reasonable price. The Basic damper MSRP starts at $750.00, which includes 4 springs and 4 shocks. Compared to the "sleeve type" coil over, the Type Basic has a more exclusive set up for a better balance of suspension travel and damping force.
* High performance and cost effective.
* Ride Height adjustable.
* New paint coating for rust prevention.
* Pillow ball mounts are optional (on certain applications).
* Exclusive design for USA vehicle specifications.
(only available for the U.S.A Market).
* Available for overhaul.
<U>Contents of damper kit:</U>
Height Adjustable shock absorber x4, Main spring x4
Lower spring seat x4, Seat lock x4, Thrust washer x4
Bump rubber x4, Dust cover x4
Hook spanner x2, Instruction manual
*Strut suspension comes with upper spring seat.
<U>TEIN SUPER STREET DAMPER:</U> PM FOR PRICE!!!
TEIN has developed advanced technology to design the shell case and stroke to bring out the full potential of your vehicle.
These features of the TEIN Super Street Damper kit were designed with greater performance to satisfy all your driving demands. This high performance damper can be used for weekend racing and/or daily driving.
The discomfort caused by uneven roads or bumps are eliminated on daily street use. For race use, the ride height adjustable system enables you to adjust ride height and 16 levels of damping force.
In other words, you can set your vehicle to meet all situations!
* 16 levels of damping force adjustment (compression and rebound together).
* Ride height adjustable.
* Exclusive design for USA vehicle specifications (only available for the U.S.A Market).
<U>TEIN TYPE FLEX DAMPER:</U> PM FOR PRICE!!!
TEIN Type FLEX damper kit was designed to provide driving comfort and sports performance with its full-length adjustment system. We have incorporated separate height and preload adjustments, which allows you to have various set-ups to meet different road conditions. The FLEX Damper kit includes pillow ball upper mounts and is compatible with the EDFC, for maximum performance for the streets.
* Full-length adjustment and height adjustment for separate setting of the height and spring preload.
* Teflon coating for rust prevention.
* Newly designed spring seat and spring seat lock for easy height adjusting.
* Pillow ball upper mounts are included.
* Compatible with EDFC.
Lower spring Seat x4,Spring Seat lock x12
<U>TEIN PILLOW BALL UPPER MOUNTS:</U> PM FOR PRICE!!!
TEIN's pillow ball (spherical bearing) upper mount is designed for each individual model of the vehicle. By remaining the positioning design of upper spring and shock absorber close to manufacture's standards, TEIN's pillow ball upper mount keeps height change to the minimum and maintains the stroke center.
*The rubber bush is replaced with a pillow ball which eliminates the load input compliance, reduces the change of alignment to improve the grip of the tire.
*NMB's (The world's top spherical bearing manufacture) pillow ball is used.
*Ultra duralumin A2017S-T4 (aircraft material) is used for upper seats and adjusting plates with anodized aluminum to have maximum strength and durability.
*For the Mcpherson strut suspension(only for front) models, the camber angle is adjustable. This creates wide varieties of different suspension settings according to the road and tire conditions.
*High tension material S45C is used for serration bolts. As it is already inserted with high press, installation time has been completely reduced. With the original long bolt design, it can be easily mounted and gives enough thread for the strut tower bar to be fitted.
<U>TEIN HOOD DAMPER:</U> PM FOR PRICE!!!
This product is only compatible with the OE hood.
Easy-To-Install!
HOOD DAMPER is designed to be installed without any modification to the vehicle, so that many users can install by themselves. All needed is some simple tools!
'Loosen bolts. Put HOOD DAMPER in place. Tighten bolts.' That's basically all there is to it. Even a person who has never worked on vehicle can install HOOD DAMPER easily and quickly without any hassle.
* For some vehicle models, resin cover needs to be cut or removed.
* Though HOOD DAMPER has been fully tested for interference with the vehicle body, it may interfere due to individual differences.
Please carefully check for any interference upon installation, and make sure there is no interference prior to use.
Lightweight & Compact
HOOD DAMPER is designed to be lightweight and compact, so that it does not get in the way of any works around the engine bay. As the main body of the damper only weights 200g and the extension that adjust the full-open angle of the hood is made of Aluminum, the product is amazingly lightweight even with all parts/components attached.
Opening-Heavy-Hood Made Easy!
Hoods are usually made of steel. The bigger the vehicle is, the heavier the hood is. Opening and closing the hood can be extremely troublesome, especially in a case of emergency for people who does not do work on his/her vehicle on regular basis. Many people want to open / close the hood much more lightly and easily. To meet such demands, TEIN has developed HOOD DAMPER.
Highly Durable!
HOOD DAMPER has met our strict quality standard and passed one hundred thousand times of Expansion & Contraction Test. In consideration of severe use conditions, as it is placed inside the engine bay, surfaces of each and every part are specially treated for corrosion-proof to stand 5 years of use.
* Proven by brine spraying tests, under the conditions regulated by TEIN, for equivalent of 5 years of general use
(by our own conversion ratio).
PICK UPS AVAILABLE BY APPOINTMENT ONLY, PLEASE PM ME FOR DETAILS
<U>PAYMENTS ACCEPTED:</U>
PAYPAL: KOYO_AERODYNAMICS@SBCGLOBAL.NET(Please add 3.3%)
CREDIT CARD: VISA, MASTERCARD, DISCOVER
CHECK/MONEY ORDER: MAKE PAYABLE TO
KOYO AERODYNAMICS
PO BOX 5683
EL MONTE, CA 91734
Modified by koyo-industries.com at 11:25 AM 3/13/2007
Old Mar 13, 2007 | 05:42 PM
VDMTom's Avatar
TEIN HOOD DAMPER for 94-01 Acura Integra shipped to 94544
Old Mar 14, 2007 | 11:46 AM
Blk00EJ8's Avatar
Default Re:
PM'd
Old Mar 15, 2007 | 05:21 PM
betterwind's Avatar
Default Re: Re: (Blk00EJ8)
tein ss for 97 civic sedan shipped to 23113
Old Mar 15, 2007 | 06:54 PM
Default Re: Re: (betterwind)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by betterwind &raquo;</TD></TR><TR><TD CLASS="quote">tein ss for 97 civic sedan shipped to 23113</TD></TR></TABLE>
pm'ed
Old Mar 15, 2007 | 06:55 PM
Default Re: (VDMTom)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VDMTom &raquo;</TD></TR><TR><TD CLASS="quote">TEIN HOOD DAMPER for 94-01 Acura Integra shipped to 94544</TD></TR></TABLE>
pm'ed
Old Mar 15, 2007 | 09:23 PM
Default Re: (koyo-industries.com)
all pm's replied
Old Mar 16, 2007 | 09:40 AM
For more info or to place an order please call 562.786.0272(ask for Ray) or visit our website http://www.koyo-industries.com
Old Mar 19, 2007 | 07:08 AM
all pm's replied
[B]
To place an order please call 562.786.0272(ask for Ray) or visit our website http://www.koyo-industries.com[/B]
Old Mar 20, 2007 | 08:33 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by koyo-industries.com &raquo;</TD></TR><TR><TD CLASS="quote">all pm's replied
[B]
To place an order please call 562.786.0272(ask for Ray) or visit our website http://www.koyo-industries.com[/B]</TD></TR></TABLE>
Old Mar 20, 2007 | 06:57 PM
jakescakesz06's Avatar
tein ss
no pillow
94 civic coupe shipped 22003?
Old Mar 20, 2007 | 09:47 PM
Default Re: (jakescakesz06)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jakescakesz06 &raquo;</TD></TR><TR><TD CLASS="quote">tein ss
no pillow
94 civic coupe shipped 22003?</TD></TR></TABLE>
pm'ed
Old Mar 21, 2007 | 05:25 AM
cb7pr's Avatar
tein ss
no pillow
91 civic Si Hatch shipped to 33434
Old Mar 21, 2007 | 02:58 PM
Default Re: (cb7pr)
all pm's replied
Old Mar 22, 2007 | 07:41 AM
Old Mar 22, 2007 | 06:25 PM
EK Josh's Avatar
Could you please PM me a price on some superstreet coilovers with pillowball mounts for a 96-00 civic shipped to 92840. Thanks
Old Mar 22, 2007 | 07:14 PM
Default Re: (EK Josh)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK Josh &raquo;</TD></TR><TR><TD CLASS="quote">Could you please PM me a price on some superstreet coilovers with pillowball mounts for a 96-00 civic shipped to 92840. Thanks </TD></TR></TABLE>
pm'ed
Old Mar 24, 2007 | 09:05 AM
t_dot_SiR's Avatar
Default Re: TEIN PRODUCTS: DAMPERS, PILLOW BALL UPPER MOUNTS, HOOD DAMPERS (koyo-industries.com)
what is the price for a set of Tein SS for the 1998 prelude SH?
and how much is shipping to canada?
Old Mar 24, 2007 | 11:04 AM
Default Re: TEIN PRODUCTS: DAMPERS, PILLOW BALL UPPER MOUNTS, HOOD DAMPERS (t_dot_SiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t_dot_SiR &raquo;</TD></TR><TR><TD CLASS="quote">what is the price for a set of Tein SS for the 1998 prelude SH?
and how much is shipping to canada?</TD></TR></TABLE>
PM'ED
Old Mar 26, 2007 | 09:18 AM
pm's replied
Old Mar 27, 2007 | 09:30 AM
new order's shipped
Old Mar 30, 2007 | 01:27 PM
pm's replied
All New Order's Shipped
Old Apr 3, 2007 | 09:09 AM
Old Apr 4, 2007 | 10:06 AM
pm's replied
Old Apr 5, 2007 | 11:07 AM
