Vtec Kick - Got Torque (dyno sheet)
Old May 22, 2002 | 11:43 PM
Rocket's Avatar
Default Vtec Kick - Got Torque (dyno sheet)
This was 1.9L LS/Vtec with a stock B16A head GSR cams running Hondata stage IV
[Modified by Rocket, 5:22 PM 5/24/2002]
[Modified by Rocket, 5:28 PM 5/24/2002]
[Modified by Rocket, 11:21 PM 6/3/2002]
Old May 22, 2002 | 11:48 PM
Kamin's Avatar
Default Re: Vtec Kick - Got Torque (Rocket)
Old May 22, 2002 | 11:52 PM
Rocket's Avatar
Default Re: Vtec Kick - Got Torque (KAMiN)
Turbo was a RevHard Stage II with the tubular turbo manifold. T40e/T3.
Old May 22, 2002 | 11:53 PM
acuracing's Avatar
Only one word comes to mind: "Holygoodgodthatisnice!"
Old May 23, 2002 | 11:39 PM
dLo GSR-stolen-now-WRX's Avatar
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
that red x sure has some power
Old May 24, 2002 | 02:42 AM
Kamin's Avatar
Default Re: Vtec Kick - Got Torque (dLo GSR)
too bad your the only one that sees it
Old May 24, 2002 | 08:15 AM
Kevin's Avatar
i see a red X too, cut and paste didnt work either.
Old May 24, 2002 | 08:20 AM
John's Avatar
New User
Default Re: Vtec Kick - Got Torque (5speedv6)
Red X here too
Old May 24, 2002 | 08:21 AM
Rocket's Avatar
Default Re: Vtec Kick - Got Torque (DunReit)
Here's the link
http://us.f1.yahoofs.com/users/6b62a...NtK78Ap0B3z24a
Yahoo pics suck.
Old May 24, 2002 | 08:27 AM
Rocket's Avatar
I posted this dyno sheet because I was telling Kamin about how good GSR cams work in a Turbo application.
BTW, this motor propelled the car to a 10.58 at Pomona. This gives you a good indication of how well the RevHard turbo's work. Myles does have really good kits.
Old May 24, 2002 | 09:02 AM
John's Avatar
New User
My car seems so insignicant after seeing that powercurve...
Old May 24, 2002 | 09:03 AM
sloaccord96's Avatar
thats pretty sick dude, imagine only if he sprayed while the turbo spools up...it's be sick!! eheh
Old May 24, 2002 | 09:18 AM
John's Avatar
New User
Default Re: Vtec Kick - Got Torque (sloaccord96)
With NAAAWWWZZZZ, the driver's head would explode from the acceleration G's...
Old May 24, 2002 | 09:24 AM
Rocket's Avatar
The motor even mad more power after going to equal length manifold, a TS06 turbo, PortFlow headwork, and SpeedPro Fuel management.
The torque curve is now flat to 7800 rpms.
The reason why the torque curves tapers here is that the manifold is becoming restrictive.
Old May 24, 2002 | 09:33 AM
John's Avatar
New User
When's it's next date with the dyno?
Old May 24, 2002 | 09:36 AM
Rocket's Avatar
Actually the motor was blown at the last event and some custom pistons and rods are being made at the moment. I'll post some more of the recent dyno sheets.
Old Jun 3, 2002 | 02:20 PM
Rocket's Avatar
Default Most Recent Dyno Sheet
This is the most recent dyno run with a TS06 turbo, RevHard equal length manifold, SpeedPro ECU, Type R intake cam and GSR exhaust cam.
Old Jun 3, 2002 | 02:49 PM
TurboSedan's Avatar
New User
Default Re: Most Recent Dyno Sheet (Rocket)
God damn that is one powerful motor! How much boost are you running?
Old Jun 3, 2002 | 03:07 PM
Rocket's Avatar
Default Re: Most Recent Dyno Sheet (97CivicFerio)
25 psi. This is my friends motor. I am an all-motor groupie.
Old Jun 3, 2002 | 03:42 PM
TurboSedan's Avatar
New User
Oh, ok well those are some kick *** numbers to say the least!
25psi............yum!
Old Jun 4, 2002 | 06:55 AM
Daemione's Avatar
Good drag motor. I'm almost frightened to think of what it does below 4,000 rpms, though.
With the amount of money being spent, wouldn't some turbo-specific cams be in order?
Old Jun 4, 2002 | 09:40 AM
Rocket's Avatar
Default Re: Most Recent Dyno Sheet (Daemione)
The reason the torque curve is shaped the way it is, is because the Turbo is so damn big in addition to being a narrow range high pressure unit (TS series size 6).
And you are correct this is a drag motor and not a daily driver. IMO this motor would definitely benifit from some moderate duration high lift cams. But $$ is hard to get when you have to spend money on the whole car and when the owner doesn't have any real sponsorship money.
Old Jun 4, 2002 | 05:09 PM
MadtownSi's Avatar
WoW!!!! Mad power!
Old Jun 4, 2002 | 05:43 PM
kranked91dx's Avatar
this should pull hard as hell, the pwerfullest car I'v drive in my life was having 254 hp at the wheel, and let me tell you HOLY ****!!!' was a h22 in a 92 civic, turboed, nitrous injected. fast as hell!!!!
see ya
Old Jun 5, 2002 | 12:20 AM
Default Re: Most Recent Dyno Sheet (kranked91dx)
hooooooooooooly. ****.
