ITR LCAs + 92' civic...any problems?
Old May 22, 2002 | 10:51 PM
P()()RB@Y's Avatar
New User
Default ITR LCAs + 92' civic...any problems?
I was going to get some ITR LCAs for my civic when I buy my suspension setup.Are there any problems installing the LCAs?The front ITR LCAs are the same as civics correct?
Also if I have the rear LCAs from the ITR should I buy the shocks and coilovers for the ITR?Itll bolt up correct?
Thanks
Old May 22, 2002 | 11:33 PM
acuracing's Avatar
Default Re: ITR LCAs + 92' civic...any problems? (P()()RB@Y)
I dont know about the front's being the EXACT same, but they are similar. The rear shocks for a 92 Civic won't "bolt" on. You'll have to a little modification to the fork of the shock.
Old May 23, 2002 | 12:06 AM
P()()RB@Y's Avatar
New User
Default Re: ITR LCAs + 92' civic...any problems? (acuracing)
But the shocks for a ITR will bolt up to the LCAs right?
Thanks
Old May 23, 2002 | 02:17 AM
infamousALLMTR's Avatar
got the whole itr 5 lug setup + rims. PM me or email me if interested bendcable.com
Old May 23, 2002 | 05:57 AM
owen_the_soyboy's Avatar
Thanks
YES, rear ITR shocks must be used on rear ITR LCAs. I have pics on my homepage of rear ITR LCAs and rear ITR shocks on my GSR, same fit as on a 92-95 civic. ITR LCA = stiffer bushings than other models...
The front ITR LCAs will also have stiffer bushings then other integras/civics so they are a good upgrade. Plus all of the Integra front LCA's have the bolt hole for the swaybar endlink, so you can easily run a stock swaybar up front if you get ITR/Integra front LCA's.
Old May 23, 2002 | 06:17 AM
94CivicSi's Avatar
Yes, if you're talking about the rears, your lower shock bolt will probably be seized inside the bushing sleeve and have to be cut out. Before you start the project, check those bolts to see if they're free. If not, you've got a much bigger project to deal with first.
hazard_one
Suspension & Brakes
Apr 28, 2005 05:44 PM
8o8da9speed
Nov 18, 2004 05:20 AM
egjoe
Jul 29, 2004 08:25 AM
Shark Tank
Feb 16, 2003 05:06 PM
fuguman
Aug 27, 2002 02:04 PM
