where to buy new oem harness plugs and pins
Old Mar 12, 2007 | 06:56 PM
CRXFREEK9000's Avatar
Default where to buy new oem harness plugs and pins
exactly what it says need to know so i can do some conversions on my da
Old Mar 12, 2007 | 07:36 PM
b18bEKcoupe's Avatar
I would like to know too.
Old Mar 12, 2007 | 09:49 PM
the guy on here from rywire should know but probably wont tell us since it his business. but they know where to get the pins for shure since they make those jumper harnesses
Old Mar 13, 2007 | 06:50 AM
Bakeoff's Avatar
Default Re: (CRXFREEK9000)
You can normally go to a U Pull type junkyard and just cut some out....
That's cheap as hell, and gets what you need.
Otherwise, go through honda. You can get a full kit from them with new pins of various sizes, various plugs, etc. That or individual pieces.
Also, what does this have to do with welding and fab? Put this in tech, hybrid, etc.
Old Mar 13, 2007 | 07:03 AM
mh's Avatar
mh
Default Re: (Bakeoff)
I got pins through Tony1.
Old Mar 13, 2007 | 07:50 AM
it has to do with fab because i need these parts so i can fab condersion harness for my da
Old Mar 13, 2007 | 08:33 AM
tepid1's Avatar
PM Joe (locash) here on HT. He has the hook up.
Old Dec 29, 2007 | 06:19 PM
nskforlife's Avatar
Default Re: (tepid1)
i just searched digikey and found a couple that look like the oem ones.
theres a couple sizes so i bought the two sizes which the ecu pins might be:
the 24-18awg terminals part number: A25554-ND
and the 20-14awg terminals part number: A25561-ND
i'll post up which one or if both work when i minime my friends ride. then the mystery will be solved as to where to find these pins!!!
if you download the digikey catalog, all of these connectors are on page 214. hope this helped a few of us out
Old Dec 29, 2007 | 08:05 PM
xenocron's Avatar
Default Re: (nskforlife)
You can buy them from manufacturer, but you have to buy in Quantity
Old Dec 30, 2007 | 11:23 AM
matt k's Avatar
Default Re: (xenocron)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xenocron &raquo;</TD></TR><TR><TD CLASS="quote">You can buy them from manufacturer, but you have to buy in Quantity</TD></TR></TABLE>yup ive found alot of info on the plugs/pins . i have tried buying from some of the harnes adapter people most of them whont sell to you or charge way to much. i might do a bulk buy on just the pins and use old connectors. im going to do some more calling after the new year
Old Dec 30, 2007 | 06:54 PM
jweller's Avatar
Default Re: (bob menuts)
most of those plugs are made by a company called Amp. I have called up their distributors before for my job and gotten them to send me sample parts. Tell them you work for (insert name of large company), you are a product engineer of some sort, you are considering several plugs and need one or two of their plugs for evaluation and prototyping. take the time to get EXACT part numbers. If asked tell them you will be doing an initial production run of 10k
You can 1 or 2 of almost anything this way, but don't get greedy.
Old Jan 2, 2008 | 08:26 PM
sicsixone's Avatar
let me know i will be in for 50 pieces.i had gone to honda today thinking that maby the technitions had some kind of repair kit.all they have are the pins with a 10" lead.i am ready to do my wiring harness for my car and really need these pins.
maby we can move this post to drag racing.
Old Jan 2, 2008 | 08:47 PM
Tyler H's Avatar
Default Re: where to buy new oem harness plugs and pins (CRXFREEK9000)
http://www.aempower.com/ViewCa...ID=84
You'll want the Plug-N-Pin kits. Cross reference the AEM EMS part numbers to figure out what vehicles the connectors are for. Should be available through any AEM dealer.
The Bosch fuel injector plug kit is really nice as well. No more fumbling with that stupid OE wire clip to release. The AEM connectors have a nice big wire clip the you squeeze to release.
Old Jan 4, 2008 | 04:03 AM
SJersey's Avatar
Default Re: where to buy new oem harness plugs and pins (Tyler H)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyler H &raquo;</TD></TR><TR><TD CLASS="quote"> http://www.aempower.com/ViewCa...ID=84
The Bosch fuel injector plug kit is really nice as well. No more fumbling with that stupid OE wire clip to release. The AEM connectors have a nice big wire clip the you squeeze to release.</TD></TR></TABLE>
http://injector-rehab.com/outp...l.htm
For "squeeze" style injector connector for obd1 and obd2
-OBD1 = 6-104
-Not listed, but a picture show lower on the page (item 6-107 is the number, but shown in 6-203) OBD2 injector connector
Hope that helps
Old Jan 4, 2008 | 09:05 PM
nskforlife's Avatar
Default Re: (jweller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jweller &raquo;</TD></TR><TR><TD CLASS="quote">most of those plugs are made by a company called Amp. I have called up their distributors before for my job and gotten them to send me sample parts. Tell them you work for (insert name of large company), you are a product engineer of some sort, you are considering several plugs and need one or two of their plugs for evaluation and prototyping. take the time to get EXACT part numbers. If asked tell them you will be doing an initial production run of 10k
You can 1 or 2 of almost anything this way, but don't get greedy. </TD></TR></TABLE>
lol sounds like you've thought this out. haha niice.
[edit 1/8/08] so i got the pins in the mail today, and they DO say AMP on them...
have yet to test fit them, but they are visually the same, and i can guarantee you 99.99% that they fit.
i'm gonna test fit them and possibly sell them if theres enough demand. but right now i got a whole lot on my plate ( moving into a new house)
but once i get settled in and a bunch of bs off my to do list, i'll start making up some charts on which ones go where. wish me luck
Modified by nskforlife at 11:07 PM 1/8/2008
Old Jan 16, 2008 | 09:10 PM
nskforlife's Avatar
those are very crappy pics, but thats them...
Old Jan 17, 2008 | 07:02 AM
tepid1's Avatar
^^^ Why did you even post those pics.... that is terrible.
Old Jan 19, 2008 | 07:59 AM
nskforlife's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tepid1 &raquo;</TD></TR><TR><TD CLASS="quote">^^^ Why did you even post those pics.... that is terrible.</TD></TR></TABLE>
they get the job done. dont hate on the picture phone. lol
Old Jan 19, 2008 | 05:34 PM
soulpwr's Avatar
Blurry pictures and a pissy mattress
Old Jan 21, 2008 | 05:52 AM
mmuller's Avatar
Mad Scientist
Default Re: (soulpwr)
anyone know what series oem obd1/2 connectors are?
havent been able to find it
Modified by mmuller at 8:42 PM 2/1/2008
Old Jan 31, 2008 | 07:21 PM
nskforlife's Avatar
Default Re: (mmuller)
ive been looking thru their entire catalog, i think honda got with amp to manufacture them sole for honda with honda having the only buying rights to them... but i'm still searching.
Old Feb 1, 2008 | 12:52 PM
tepid1's Avatar
I always thought it was Sumitomo that made the pins, sockets and plugs....
http://www.sewsus.com/welcome.html
Old Feb 1, 2008 | 04:42 PM
mmuller's Avatar
Mad Scientist
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tepid1 &raquo;</TD></TR><TR><TD CLASS="quote">I always thought it was Sumitomo that made the pins, sockets and plugs....
http://www.sewsus.com/welcome.html</TD></TR></TABLE>
ahhh maybe thats why could not find them... haha thanks
HW series for obd1
looks like most HM series for obd0
Modified by mmuller at 9:43 AM 2/3/2008
Old Feb 2, 2008 | 07:58 PM
nskforlife's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">
HW series for obd1
looks like most HM series for obd2</TD></TR></TABLE>
my friend just told me about that company too. lol And they're main hub's only an hour from where i live...
http://swsct.sws.co.jp/index_e.html
they're there somewhere. theres only like 60 pages to search thru tho...
Modified by nskforlife at 11:22 PM 2/2/2008
Old Feb 3, 2008 | 02:18 AM
brightside's Avatar
look under hw sealed series, many obd1 type plugs
edit: oops, didn't read the post 2 up
edit again: looks like hm is for obd0 harness plugs, if you click on series features, it shows the semi-clear white plugs. also, mt sealed series have some obd0 as well
edit once again : 6240-5181 and 6240-1181 look like obd0 ecu-A plug. would have to measure to verify, but picture looks like it, and it's an 18 pin plug
Modified by brightside at 3:31 AM 2/3/2008
