can you use 84mm pistons in b16a3 block?
Old Mar 12, 2007 | 03:37 PM
ALLMOTOR CRX's Avatar
Default can you use 84mm pistons in b16a3 block?
i bought some b20 pistons for a b20 block but i change my mind for using them on my b20.. and i wanted to know if they would fit a b16a3 block with eagle, or darton sleeves.. you know resleeving the block.. but before i do i want to make sure i will be able to use them in my b16 block the pistons are arais pisonts 12.5 compression i bought them for b20 but will they fit b16 sleeved to 84mm? thanks ..
Old Mar 12, 2007 | 04:17 PM
dbiker207's Avatar
Default Re: can you use 84mm pistons in b16a3 block? (ALLMOTOR CRX)
ya they will work with sleeves, you can bore the sleeves up to 85.5mm i think, but 84 is deffinently ok
Old Mar 12, 2007 | 08:50 PM
allright then thanks.. but what type of crankshaft can i use any or aftermarket?
Old Mar 12, 2007 | 09:29 PM
milano sir-g's Avatar
wow. search man. My mother can wonder onto this site and figure out that she could run 84mm pistons in her delsol engine.
Old Mar 12, 2007 | 09:39 PM
del_slow420's Avatar
Default Re: (Milano SiR-G)
uh u use the b16 crank and b16 rods the pistons can be put in anything thats resleeved and bored to 84mm
Old Mar 13, 2007 | 03:37 AM
salman's Avatar
Any thing is possiable.
Old Mar 13, 2007 | 03:39 AM
salman's Avatar
what will be the advantage of installing these pistons.
I think you will face head to pistons problem
Old Mar 13, 2007 | 10:55 AM
b16nonoy's Avatar
you need to get sleeves...I myself am running 84mm JE 11.5:1 pistons...got my block resleeved with Darton Ductile Iron Sleeves
Old Mar 13, 2007 | 01:47 PM
b16nonoy did you ever get a piston to valve contact because of the high compression piston?
Racer9999
Feb 3, 2016 10:17 PM
zongetsu
May 27, 2012 05:37 AM
cmerce
May 19, 2006 12:40 PM
FastGsr95
Nov 23, 2005 06:18 PM
ilsimsli
Apr 14, 2005 08:37 PM
