New motor for the accord
Old Mar 12, 2007 | 09:19 AM
Mr.Luder's Avatar
Default New motor for the accord
my girl has a 97 honda accord and i have been searching for a new motor for it and have only been able to find 94-96 f22b non-vtecs so after a long while of searching, i bought one from a local engine shop with about 20-50k miles on it. The guy says to make it work with the 97 honda accords I would have to swap out the oil pumps and crank angel sensor. Is there anything else I need to swap over? If so, what else would I need?
Also, will it pass emissions if i use that motor? isnt that the reason we swap oil pump and crank angel sensors? lemme know. thanks
Modified by Mr.Luder at 10:34 AM 3/12/2007
Old Mar 12, 2007 | 09:24 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: New motor for the accord (Mr.Luder)
What model Accord does your girl have? EX, LX, DX, SE?
The motor you bought, was it a F22B (DOHC non-VTEC) or a F22B2 (SOHC non-VTEC).
Old Mar 12, 2007 | 09:27 AM
Mr.Luder's Avatar
Default Re: New motor for the accord (TouringAccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TouringAccord &raquo;</TD></TR><TR><TD CLASS="quote">What model Accord does your girl have? EX, LX, DX, SE?
The motor you bought, was it a F22B (DOHC non-VTEC) or a F22B2 (SOHC non-VTEC).</TD></TR></TABLE>its a 97 honda accord lx original motor f22bs sohc new motor f22b also sohc
Old Mar 12, 2007 | 09:41 AM
H-T Order of Merit
so both motors are a F22B2.
What year Acord did the motor you buy come from?
Old Mar 12, 2007 | 11:03 AM
Mr.Luder's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TouringAccord &raquo;</TD></TR><TR><TD CLASS="quote">so both motors are a F22B2.
What year Acord did the motor you buy come from?</TD></TR></TABLE>no one is a f22b2 and one is a f22b
the f22b is a 94-95 jdm motor i guess
Old Mar 12, 2007 | 11:13 AM
H-T Order of Merit
but they are both SOHC non-VTEC right?
Old Mar 12, 2007 | 11:16 AM
Mr.Luder's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TouringAccord &raquo;</TD></TR><TR><TD CLASS="quote">but they are both SOHC non-VTEC right?</TD></TR></TABLE>yes
Old Mar 12, 2007 | 11:21 AM
H-T Order of Merit
ok, they are the same engine except it sound like you bought a OBD1 engine when you have a OBD2 car. I'm not sure what needs to be swapped between the OBD1 and 2 engines.
Old Mar 12, 2007 | 12:18 PM
Mr.Luder's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TouringAccord &raquo;</TD></TR><TR><TD CLASS="quote">ok, they are the same engine except it sound like you bought a OBD1 engine when you have a OBD2 car. I'm not sure what needs to be swapped between the OBD1 and 2 engines.</TD></TR></TABLE>I know i have to swap the oil pump with the crank angel sensor because its a jdm motor but do i need to swap the dizzy? the obd2 has a external ignition coil and it looks the the new one doesnt
Old Mar 12, 2007 | 01:34 PM
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.Luder &raquo;</TD></TR><TR><TD CLASS="quote">I know i have to swap the oil pump with the crank angel sensor because its a jdm motor</TD></TR></TABLE>
why is that? just wondering cause I haven't heard of people having to change either of those.
Old Mar 12, 2007 | 10:36 PM
Mr.Luder's Avatar
Bump! Do i need to chane the harness with my old 97 harness? how bout the distributor?
Old Mar 13, 2007 | 01:42 AM
SuperSlow's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.Luder &raquo;</TD></TR><TR><TD CLASS="quote">I know i have to swap the oil pump with the crank angel sensor because its a jdm motor but do i need to swap the dizzy? the obd2 has a external ignition coil and it looks the the new one doesnt</TD></TR></TABLE>If you are planning on passing smog legit, you had better stick with obd2.
you can get obd2 f22 and f23 for cheap as well, and it will be an easier swap. Less wiring/conversion harness, dizzy/fuel, resistor box, crank sensor, fuel pump to worry about. If you are sticking with f22b1/b2, you are better off just getting obd2.
I have not heard of oil pump changes either.
Good luck.
Old Mar 13, 2007 | 06:02 AM
Mr.Luder's Avatar
Default Re: New motor for the accord (SuperSlow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuperSlow &raquo;</TD></TR><TR><TD CLASS="quote">If you are planning on passing smog legit, you had better stick with obd2.
Good luck.</TD></TR></TABLE>i guess swapping over the oil pump is for emissions, the oil pump has the crank angel sensor mounted on to it. can't I just use the long block with all the obd 2 stuff such as wire harness dizzy injectors from the old motor?
grocery_getterr
Jul 30, 2015 04:46 PM
Silvertc
Aug 2, 2010 09:08 AM
94c1v1cex
Aug 21, 2007 10:24 PM
