HELP:: Do ITR's Rear LCA fit on the 99/00 civic SI?
Old May 22, 2002 | 08:59 PM
tjtruong's Avatar
New User
Default HELP:: Do ITR's Rear LCA fit on the 99/00 civic SI?
need to know ASAP. Want to put ITR coilover suspension on a 99si. Any help will be appreciated.. Thanks
Thomas
Old May 22, 2002 | 09:02 PM
Mike B's Avatar
Default Re: HELP:: Do ITR's Rear LCA fit on the 99/00 civic SI? (tjtruong)
Well, maybe this will help. My friend put the rear suspension off a Del Sol (discs) on a 96+ Civic Coupe (drums). Fit just fine.
GSR suspension will fit on a Del Sol.
ITR rear LCA's will fit on GSRs.
Do the conversion, yes
Old May 22, 2002 | 09:06 PM
Scorpaznatica's Avatar
New User
Default Re: HELP:: Do ITR's Rear LCA fit on the 99/00 civic SI? (Crazy Bovine)
err nope, have to modify the lca from the itr to fit the EK's.
your friend probably just change the struts from delsol to EK, so the lca wasnt needed. but ITR struts are different so you need the lca.
Old May 22, 2002 | 09:17 PM
tjtruong's Avatar
New User
Default Re: HELP:: Do ITR's Rear LCA fit on the 99/00 civic SI? (spooGEN)
how would i go about modifying it? please explain
Old May 22, 2002 | 09:31 PM
New User
modifying means lengthening the lca among other things, I never done it myself... too much headache. just get a sus made for SI
Old May 23, 2002 | 05:48 AM
mexipino26's Avatar
what can I use to put TypeR LCA on my 99 si? my budy posted this yesterday helping my out. I have N1 Type R coilovers and I want to find out how I could make it work please help me out.
Old May 23, 2002 | 05:56 AM
Dipshit Dan's Avatar
Default Re: HELP:: Do ITR's Rear LCA fit on the 99/00 civic SI? (mexipino26)
Can't. You'd have to cut and reweld the control arm and I'd be worries about it's integrity at that point.
Old May 23, 2002 | 07:12 PM
tjtruong's Avatar
New User
Default Re: HELP:: Do ITR's Rear LCA fit on the 99/00 civic SI? (God)
thank you...... Now we now for sure.......
one more thing..... what if we found CTR LCA's ? Would that work? OR how about swaping GSR stuff in there to fit the ITR LCA?
tj~who is trying to find a way to use the ITR LCA.
Thanks
Thomas
Old May 24, 2002 | 01:53 PM
Mario's Avatar
You're not one to talk about integrity
Anyways, a crazy guy @ HASport was going to make ITR style rear lca in complete billet for the EK so he could run his TEIN coilovers that was meant for the ITR. Dunno what happened though.
Old May 24, 2002 | 01:55 PM
Mario's Avatar
CTR lca is the same as Si...no difference.
As far as I know only the ITR and older CRX (as well as JDM EG) uses ITR style rear lca. They're all the same length, so it would not be compatible with the EK.
Old May 24, 2002 | 03:24 PM
mexipino26's Avatar
I guess I have to sell them thanks my friend posted this for me
Thomas
APEXi N1 damper coilovers with pillow mounts how much $? used five months I will try to get pictures up later. thanks
carlos8
Oct 5, 2011 01:39 PM
mikel_143
Suspension & Brakes
Nov 26, 2006 11:24 PM
Del_Sol_s
Jul 22, 2005 09:24 AM
EBPSI
Mar 10, 2003 06:45 PM
mexipino26
May 23, 2002 02:36 PM
