Need help identifying this part? HUB?
Old May 22, 2002 | 08:57 PM
Mike B's Avatar
Default Need help identifying this part? HUB?
America's Tire stripped one of my wheel studs a few days ago. Well, they sent me up the road to this shop who replaced it in about 30 minutes "without breaking" the wheel bearing. Well, here I am and bearing works great with no play.
I observed the whole installation/replacement because Im real meticulous on who works on my car. I hate it when people rest their body weight on my fenders. Luckily left with no dimples.
ANYHOW, here is the order process of parts removal that I observed:
1) Lugs and Wheel
2) 32mm Axle Nut
3) Rotor Locator Screws
4) Caliper
5) Off comes the rotor
6) Then they pulled this part off, holds the studs. HUB?
They pulled it off with this long rod that had a sliding weight. The long rod attaches to the hub by tightening 2 lugs so itll come off when the weight is thrown.
1. What is this part called?
2. What is the INSIDE diameter of this part?
Im thinking its the hub?
Old May 22, 2002 | 09:12 PM
ppihctyper's Avatar
Default Re: Need help identifying this part? HUB? (Crazy Bovine)
Spindle... do i win a prize?
Old May 22, 2002 | 09:18 PM
Mike B's Avatar
Default Re: Need help identifying this part? HUB? (ppihctyper)
Just my appreciation for now. Do you know the inside diameter. Do you know if they the ID of the ITR Spindle and the GSR Spindle are the same.
RyanR's Avatar
The sliding weight thing is called a slide hammer, no idea on the inner diameter.
Oh nevermind, you wanted to know the name of the suspension piece. Yes, it's the hub.
[Modified by RyanR, 10:19 PM 5/22/2002]
Old May 22, 2002 | 09:21 PM
Mike B's Avatar
Default Re: Need help identifying this part? HUB? (RyanR)
Now Im confused.....haha Hub or Spindle?
Old May 22, 2002 | 10:08 PM
Reid's Avatar
Global Moderator
Yes, it's the hub.
Old May 23, 2002 | 03:49 AM
Asahi's Avatar
hub, spindle, tomAto, tOmato.
I would call it the hub.
WHy the interest in the ID?
Old May 23, 2002 | 06:34 AM
sgT's Avatar
sgT
Default Re: Need help identifying this part? HUB? (Asahi)
hub has the wheel studs in it
spindle holds the bearing that the hub goes into.
Old May 23, 2002 | 07:32 AM
Mike B's Avatar
See if the HUB will fit anothe vehicle. Do you know by any chance?
Old May 23, 2002 | 07:34 AM
sgT's Avatar
sgT
hub should fit any 88+ civic or 90+ integra
Old May 23, 2002 | 07:57 AM
Mike B's Avatar
Default Re: Need help identifying this part? HUB? (sgT)
Same goes for the rear? SGT, you know what Im trying to do right?
Old May 23, 2002 | 08:02 AM
sgT's Avatar
sgT
rear as well, however you need to check caliper spacing.
I assume you are just trying to swap hubs and calipers rather than buying the
entire susp setup.
classciv
Aug 27, 2004 06:24 PM
tilt
Mar 2, 2003 06:08 PM
JeffS
13
Oct 24, 2002 10:14 AM
CRX7
Mar 17, 2002 01:44 PM
InfamousRS
Feb 11, 2002 09:36 PM
