D16Y8 Tranny swaps help...
Old Mar 12, 2007 | 12:03 AM
[HID]Sohc_Life's Avatar
Default D16Y8 Tranny swaps help...
I have a D16y8 motor and I need a new D series tranny. Which one is the best D series swap? And wat is the difference from a D16y8 and Y7? thanks...
Old Mar 12, 2007 | 12:24 AM
ke98248's Avatar
Default Re: D16Y8 Tranny swaps help... ([HID]Ej.D16Y8)
If you have a d16y8 engine, go with the d16y8 tranny. It will serve you well.
Old Mar 12, 2007 | 01:34 AM
hatchnideas's Avatar
y7 is the dx transmission- really looonggg gears not good for acceleration more for long highway drives
y8 is the ex trans- much better gearing for acceleration
if you want good performance go with either a 92-95 ex/si or a 96-00 ex trans
it will have a round stamp by the fill plug in the case i believe that will say B000
dx stamp shows A000 make sure you check these marks before you buy it. ive had places try and pawn dx trannies on me saying " oh they are the same" yeah right
s-20 is 92-95 model
s-40 is 96-00
also watch the used transmissions you get ive had two recently that had bad bearings
Old Mar 12, 2007 | 05:37 AM
97Ej6mike's Avatar
CX tranny (92-95) has longer gears than the Y7. Friends hatch went 80 in the top of 2nd gear.
Old Mar 12, 2007 | 11:33 AM
sql_civic's Avatar
Default X2
Yes X2 on ^ and ^^
Old Mar 12, 2007 | 03:15 PM
So is the Eg si tranny and the 96-00 ex trannys are the same? or is there a difference? And any suggestion on clutch kits? Thankx
Old Mar 12, 2007 | 03:20 PM
CiViC_SOHC's Avatar
the 92-95 shift forks are weaker then the shift fork on a 96-00 thats the only difference.
Old Mar 12, 2007 | 06:25 PM
sql_civic's Avatar
Default Forks
One is steel and the other is aluminum I believe. So one bends and the other snaps!
ajason24
19
Aug 18, 2013 07:40 AM
projekt-sol
Dec 10, 2007 03:32 PM
NGUSPEED
17
Oct 2, 2005 06:38 PM
mrcch
Jan 1, 2003 10:13 AM
