Would like to hear personal preference on this topic, so i can get the right idea
Car - 98 Civic EX
Wanted motor - gsr
Question - Would you prefer to use an obd2 motor (well ECU) or would you prefer to get the obd1 and just get a conversion harnes...
lmk thanks
Wanted motor - gsr
lmk thanks
Just get the OBD2 and don't dick around with the conversion deal. Tuning software is such that it doesn't matter nearly as much what OBD you begin with unless you're trying to make 750hp - at which point OBD is relegated to the past tense by a complete-stand-alone system.
OBD2 is easier for you, so do that.
get a obd-2 cause your harness is obd-2 and you need everything to plug up directly. and if you wanna run obd-1 then just get a obd-1 ecu with a jumper harness
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fmrprojects »</TD></TR><TR><TD CLASS="quote">get a obd-2 cause your harness is obd-2 and you need everything to plug up directly. and if you wanna run obd-1 then just get a obd-1 ecu with a jumper harness</TD></TR></TABLE>
x2
x2
NOman0608
Jul 26, 2007 10:28 AM
