putting in type one header... gasket question
Old May 22, 2002 | 08:25 PM
B16A2's Avatar
Default putting in type one header... gasket question
im am installing a type one header into my 99 si and i was wondering if it is a must to replace this gasket pictured below as #3. the reason i ask is because it is on back order. i know that this is a metal gasket and i was wondering if it needed to be replace, such as if it had some sort of crush seal when it is installed.
Old May 22, 2002 | 08:30 PM
Padawan's Avatar
Darth ModerVader
Default Re: putting in type one header... gasket question (B16A2)
As long as it is in good shape, you shouldn't have to replace it.
Old May 22, 2002 | 08:49 PM
RagingAngel's Avatar
Default Re: putting in type one header... gasket question (Spec.R 00-0123)
otherwise some people have said the Mr.Gasket copper one is good also...
Summit Racing should have stacks of those?
Old May 23, 2002 | 12:05 AM
SMSP's Avatar
No, you shouldn't have to replace it. Just clean it well with some acetone or brake cleaner spray and you'll be good to go.
ondahush
Jan 10, 2006 06:46 AM
BLK98EX
Sep 25, 2004 10:21 PM
SupaTegRS
Mar 21, 2003 11:38 PM
Toda
Jun 27, 2002 11:00 AM
