Where can I find my Clutch Interlock Switch? 1995 Accord LX 4Cyl 5spd
Old Mar 11, 2007 | 05:42 PM
compint's Avatar
Default Where can I find my Clutch Interlock Switch? 1995 Accord LX 4Cyl 5spd
I'm installing a remote start alarm and need to find the CIS. If I look at the clutch pedal, I see a yellow 2 wire plug. One wire is green/red and the other looks black. Is this the harness and the wires? If so, which one?
Thanks in advance.
Old Mar 11, 2007 | 06:37 PM
TouringAccord's Avatar
H-T Order of Merit
Default Re: Where can I find my Clutch Interlock Switch? 1995 Accord LX 4Cyl 5spd (compint)
no, any yellow plug has to do with the SRS.
I'll look in my manual to see if I can find the wire your looking for.
Old Mar 11, 2007 | 06:41 PM
compint's Avatar
Default Re: Where can I find my Clutch Interlock Switch? 1995 Accord LX 4Cyl 5spd (TouringAccord)
Thanks for responding. It's a yellow plug with a black harness on it.
Old Mar 11, 2007 | 06:48 PM
H-T Order of Merit
wait, nm. I may have been mistaken on what I was thinking. When your looking at the clutch pedal, you want the switch thats located the highest. It's the switch that is switched when the clutch pedal is pressed. I didn't find the wire colors yet, give me a sec.
Old Mar 11, 2007 | 07:09 PM
H-T Order of Merit
ok, sorry it took a while.
The two wire colors are BLU/RED and BLK/GRN.
Looks like the BLU/RED wire is coming from the under-dash fuse box and the BLK/GRN wire runs to the starter relay.
Old Mar 12, 2007 | 07:45 PM
compint's Avatar
OK, got it. After connecting all the wires on this alarm/remote start/keyless entry, everything works except the remote start. The manual says to put it into reservation mode, which i did, then close the door. The engine shuts off, but when I press the button to autostart it, the battery comes on like the key was on, but the engine doesn't even turnover. Do I have a wire misconnnected. Thank for your help!!
Old Mar 13, 2007 | 04:17 AM
H-T Order of Merit
which wire did you splice into at the clutch interlock switch? the BLU/RED or the BLK/GRN?
Old Mar 13, 2007 | 06:30 PM
compint's Avatar
OK, I actually tried both wires. Neither worked. I was using a T-clip though. I'm going to try the black/green wire without the t-clip.
Old Mar 13, 2007 | 10:42 PM
compint's Avatar
OK, found another gray connector on top of the clutch plunger. It has a pink wire and a black wire in it. I disconnected it and the car started so I assume that's not the wire, but any idea what it's for?
Thanks
notfastenough
Audio / Security / Video
Oct 20, 2008 09:03 PM
compint
Mar 24, 2007 12:44 PM
Circuit8
May 8, 2003 07:23 AM
arsenaldragster
20
Apr 1, 2003 01:03 PM
Mark27
Apr 13, 2002 08:30 PM
