91 crx hf transmision
Old Mar 11, 2007 | 03:27 PM
mihaelrosas's Avatar
Default 91 crx hf transmision
i just finished changing my clutch and now i need to fill the tranny with fluid. but i dont know where to fill it at? and how much fluid should i use?
Old Mar 11, 2007 | 03:31 PM
powerpro_69's Avatar
Default Re: 91 crx hf transmision (mihaelrosas)
should be a bolt u take out on the top as for the fluid lvl call honda or maybe some one else will know
Old Mar 11, 2007 | 03:35 PM
Default Re: 91 crx hf transmision (powerpro_69)
there is a bolt on top of the tranny under the starter. dont know if thats where u fill it at? so i think i might hold on installing the starter for a little
Old Mar 11, 2007 | 04:19 PM
what kind of oil does the tranny use?
Old Mar 11, 2007 | 05:25 PM
BlueCrxNC's Avatar
Standard 10w30 motor oil
Old Mar 11, 2007 | 05:30 PM
Default Re: (BlueCrxNC)
thank you, do you know where to fill it? and i have noticed that i have to get the axel in place before fillin it or I am wrong?
Old Mar 11, 2007 | 05:47 PM
BlueCrxNC's Avatar
There are several ways to fill the tranny up. And no you don't have to have the axles in first, but you would want to top it off after placing them back in. You do want the car level while checking fluid level.
Fill spots:
One 19mm Bolt Cap underneath the Starter (My favorite if starter is already out)
17mm OEM Fill bolt on the Passengerside to the rear area of the axle: Have to use a hose and funnel to fill here
Remove the VSS (Vehicle Speed Sensor) and fill in it's place: Be careful, dirt and grime is likely to fall into the hole upon removing the sensor.
Old Mar 11, 2007 | 06:00 PM
thats what i thought, it would be alot easier to fill it using the 19 mm bolt under the started. might as well fill it before i reinstal the starter
Old Mar 11, 2007 | 06:30 PM
BlueCrxNC's Avatar
Just don't lose that spring that will pop out when you unscrew that 19mm bolt.
JdM_RACeR07
Dec 5, 2006 03:49 PM
roterx7
39
May 30, 2006 09:08 PM
FourthGenHatch
14
Apr 15, 2003 11:18 AM
EF-9SiR
Nov 29, 2002 11:15 AM
showstopper
Aug 26, 2002 09:06 PM
