96 dx with a gsr swap question
Old Mar 11, 2007 | 02:42 PM
1SickEG's Avatar
Default 96 dx with a gsr swap question
ok guys have a 96 dx coupe....i have replaced the old non vtec harness with the correct vtec harness...i plug up my chipped p28...make sure the vtec lines are hooked up...and the vtec is still not working...does anyone have any suggestions? i have put in 3 different chips into the ecu and vtec still does not engage...any ideas?
i also just removed this gsr swap from my buddies teg...and it did work and i kno it didnt just quit in the process of the swap..
Old Mar 11, 2007 | 02:59 PM
1SickEG's Avatar
bump
Old Mar 11, 2007 | 03:03 PM
19992civichatch's Avatar
you sure everthing is hooked up right i would double check if i was you.
Old Mar 11, 2007 | 03:29 PM
1SickEG's Avatar
my speedo stopped working as well...the speedometer was working with the gsr ecu...when i put my chipped p28 in it with a chip speedo quit working...vtec never engaged with either ecu......somethings not right...why would a p28 ecu chipped be throwing vss code and forcing vtec not to work?
Old Mar 11, 2007 | 03:51 PM
well i think if its a non chipped ecu vtec needs the vss to tell vtec when to engauge i think its above 15 mph, what happens when u put a non chipped ecu in your car?
Old Mar 12, 2007 | 03:56 AM
JDM_EK4_Coupe's Avatar
(banned)
Default Re: (19992civichatch)
I dont think it was wired correctly, take it into a shop and have it double checked.
Old Mar 12, 2007 | 04:13 AM
92'si's Avatar
Default Re: (JDM_EK4_Coupe)
vss good? selinoid good? oil ok?
baulum
Engine Management and Tuning
Feb 16, 2020 08:48 PM
skunk2unerz
21
Mar 12, 2016 03:16 PM
EGEAZY
Jan 31, 2010 07:02 AM
JDM96SpecCTR
Nov 10, 2004 09:31 PM
skunk2unerz
Aug 2, 2002 09:43 AM
