upper control arm
Old Mar 11, 2007 | 01:30 PM
soon2bdropped's Avatar
Default upper control arm
okay the boot on my upper control arm is ripped i squeeze it nothing came out but water assuming rain go in and washed all the grease out.. now my car is makin this nasty sound thats really irritating and i'm scared the joint will seperate and cause more damage....
i;m assuming its one peice and balljoint isn't sold seperately..
anybody has a DIY on this or anything at all.. don't have a manual and need to do this asap.. can this be done with hand tools.. i tried and it looks like its on there tight and for some time.. i don't want to spend more money by buying air compressor with air tools. let me know thanks..
Old Mar 11, 2007 | 01:54 PM
Loco-B's Avatar
Default Re: upper control arm (soon2bdropped)
Here are some individual ball joints.
http://www.racerwheel.com/prg-511011.html
And here is a ball joint seperator
http://cgi.ebay.com/ebaymotors...ZWDVW
Now get yourself an alignment and your all set!
Old Mar 11, 2007 | 02:15 PM
Default Re: upper control arm (accordcd_7)
can i use the hammer to bang it out or something?
Old Mar 11, 2007 | 02:19 PM
Loco-B's Avatar
On the old one yeah. But how are you going to get the new one in. Your not going to pound on it. You would have to press it in.
Old Mar 11, 2007 | 03:26 PM
don't all i do is jack the knuckle up so i can get the threaded part inside the knuckle and then bolt it up....
press what on? don't the balljoint come as one peice with the control arm what are you talkin about?
Old Mar 11, 2007 | 03:39 PM
TouringAccord's Avatar
H-T Order of Merit
yes, you are right... The upper control arm and ball joint are one piece, no press needed.
to free the ball joint from the knuckle, just go rent a ball joint seperator at AutoZone. It'll look like a big tuning fork or something. It'll be wedge shaped so as you hammer it between the upper arm and the knuckle it'll seperate the two parts. This normally isn't recommended because this will rip the ball joint boot but because you're replacing the ball joint and arm it doesn't matter.
Then just unbolt the upper arm from the car, the nuts are locate inside the engine bay. Replace in reverse order, torque the upper arm nuts to 47 lbs-ft and the ball joint castle nut to 29-35 lbs-ft. Don't forget to get an alignment after your done.
Old Mar 11, 2007 | 09:26 PM
Loco-B's Avatar
Default Re: upper control arm (TouringAccord)
Maybe i need some clarification then. I've got too much camber and im looking at these adjustable ball joints. I knew the ball joint and the upper control arm were one piece, but how would these work?
Old Mar 11, 2007 | 10:06 PM
AJ06's Avatar
u can get adjustable balljoints uf u choose to do so, u dont need the whole upper control arm
Old Mar 12, 2007 | 03:14 AM
H-T Order of Merit
in your case yes, but for what the OP is trying to do, no. The OP is just trying to replace a stock part and the easiest to do that is to just buy a stock arm/ball joint assembly and replace the whole thing.
Old Mar 12, 2007 | 06:30 PM
castle nut for the upper BJ is stripped i don't know what to do at this point..
Old Mar 12, 2007 | 06:58 PM
Loco-B's Avatar
Turbo sockets. Available at sears. Work great!
Old Mar 13, 2007 | 01:56 AM
SuperSlow's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soon2bdropped &raquo;</TD></TR><TR><TD CLASS="quote">castle nut for the upper BJ is stripped i don't know what to do at this point..</TD></TR></TABLE>If the nut is stripped, you can still back it down. it is a tapered thread. JUst compress the joint back together tightly and unscrew the nut.
Old Mar 13, 2007 | 03:16 AM
H-T Order of Merit
Default Re: upper control arm (SuperSlow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuperSlow &raquo;</TD></TR><TR><TD CLASS="quote">If the nut is stripped, you can still back it down. it is a tapered thread. </TD></TR></TABLE>
no, the thread isn't tapered, the ground shaft above the thread is tapered though.
I have some Craftsman Bolt-Out sockets that I've used to get stripped nuts off the exhaust-to-cat flange when we did a friends exhaust. They worked great, you could give those a shot.
Old Mar 13, 2007 | 04:46 PM
damn this didn't even take 10 mins to change..... jack car up take wheels off.. take the 2 17mm bolts under the hood off..... take an AIR CHISEL(omg best tool ever my boy let me borrow it) split the nut down the middle.. bam take out upper control arm put in new... time only took 25 minutes for 1st timer...
thanks you guys
anybody use alot of air tools i need help on pickin up an air ratchet.. my aim screen name is "airidein2years" without the quotes.. thanks alot
Old Mar 13, 2007 | 05:22 PM
H-T Order of Merit
glad to hear you got the castle nut off and the upper arm/upper ball joint replaced
Old Mar 13, 2007 | 05:27 PM
Black Ex Coupe's Avatar
Glad to hear you got it changed, but I was wondering how much you paid for the new uca?
Old Mar 14, 2007 | 04:52 AM
walker111's Avatar
Default Re: (Black Ex Coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black Ex Coupe &raquo;</TD></TR><TR><TD CLASS="quote">Glad to hear you got it changed, but I was wondering how much you paid for the new uca? </TD></TR></TABLE>
I paid around 200 bucks from autozone for both of them. Took me about 45 minutes in the auto zone parking lot
Old Mar 14, 2007 | 10:00 AM
zidek's Avatar
when i had that problem i replaced mine with used OEM ones from the junkyard for $40 twice (cause i busted it twice). good yours came out easy
Old Mar 14, 2007 | 06:44 PM
Default Re: (zidek)
104 with taxes... comes with bushing already. just plug and play basicially.. only 3 bolts holding the crap together..
wgbm92
May 24, 2012 08:28 PM
coojoe59
Jun 9, 2008 05:37 PM
XstouterX
Jan 9, 2006 10:31 PM
staticrex
Nov 3, 2005 12:22 PM
