Turbo D16
I have a 94 civic EX coupe with the stock D16 @114k miles. i'm in the process of building a turbo kit... first of all i have a T3 Flange on my Mani and apparently A T4 or T3/T4 wont fit on it as far as i'm told but thats only one guys opinion. i've heard that it will and i heard that a T4 flange is slightly larger so it won't... need EDUCATED advice... i'm so tired of these dumbasses trying to tell me whats going on.... also my compression is like this; | 151 | 164 | 151 | 164 | so does my
| 1 | 2 | 3 | 4 |
engine look like it could handle 8 Psi safely? some people tell me they've run D16's with higher miles @ higher boost and it was fine, but i never see these cars or they "blew a gasket or something, don't worry it'll be fine" so again i'm looking for experienced honest advice. this is my driver so i don't want to be stupid with it. i'm trying to get the most power as safely as possible. it will be tuned and intercooled so please let me know. thanks guys
| 1 | 2 | 3 | 4 |
you always have to remember its not PSI that kills motors it horspower. u could run 15 PSI on stock internals but the tune will have to be running super rich.( im just making a point and setting an example.) but if u tuned it to get power u'll blow ur **** up eventually. i would go for 5-7 and try to tune it as best as possible and it will be reliable and fast.(its all in the tune and the horespower.) u could blow ur **** up with only 5 psi so make sure u tune it good. i dont know whos tuning ur car or wut ur tuning with.
good luck
good luck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96hatchy »</TD></TR><TR><TD CLASS="quote">you always have to remember its not PSI that kills motors it horspower. u could run 15 PSI on stock internals but the tune will have to be running super rich.( im just making a point and setting an example.) but if u tuned it to get power u'll blow ur **** up eventually. i would go for 5-7 and try to tune it as best as possible and it will be reliable and fast.(its all in the tune and the horespower.) u could blow ur **** up with only 5 psi so make sure u tune it good. i dont know whos tuning ur car or wut ur tuning with.
good luck
</TD></TR></TABLE>exactly! im also in the process of turboing my d16y8 to 200whp hopefully with only 7 psi and any higher than that is pretty scary and not reliable.although i would run 11psi if i wanted to smoke a rsx!!mmuuaahhahhhaa
good luck
hmmm. well i'm not sure about the guy either. i met him through a friend...says he's tuned over 15 turbo civs and no probs. uses an ostrich i think. said it'd cost me 30 bucks to chip my ECU and he'd charge me $50 for an hour of dino tuning... he's the only person i know in spokane washington... but a T3/T4 will fit huh?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raphael »</TD></TR><TR><TD CLASS="quote">exactly! im also in the process of turboing my d16y8 to 200whp hopefully with only 7 psi and any higher than that is pretty scary and not reliable.although i would run 11psi if i wanted to smoke a rsx!!mmuuaahhahhhaa
yea, people r always thinking its PSI because that the pressure in the engine,but it s actually just ur engine making so much extra power that it goes poof! it makes sense that PSI is the reason a motor blows but its just not
</TD></TR></TABLE>yea, people r always thinking its PSI because that the pressure in the engine,but it s actually just ur engine making so much extra power that it goes poof! it makes sense that PSI is the reason a motor blows but its just not
i love misinformation
anyway, most people agree that the ~220whp range and under is the safe range, but many have pushed further. If you want more turbo D specific answers and setups, go to http://www.turbod16.com
T25 civic
Nov 13, 2002 09:28 PM
