stock hood weight vs. carbon fiber hood weight?
Old Mar 11, 2007 | 12:40 PM
whole9's Avatar
Default stock hood weight vs. carbon fiber hood weight?
How much weight would I save? 30 lbs maybe? thanks
Old Mar 11, 2007 | 12:47 PM
janz3n's Avatar
Default Re: stock hood weight vs. carbon fiber hood weight? (whole9)
im gonna say 20-40 lbs
Old Mar 11, 2007 | 12:55 PM
whole9's Avatar
Default Re: stock hood weight vs. carbon fiber hood weight? (janz3n)
That is a considerable ammount I think. It should balance the weight of my turbo setup eh?
Old Mar 11, 2007 | 01:02 PM
Ass$nyper's Avatar
Pirate General...YARRRR
Depends on what hood you are using some of the hood have metal bracings and just laid over C/F while other are all c/f.
Old Mar 11, 2007 | 01:03 PM
janz3n's Avatar
Default Re: stock hood weight vs. carbon fiber hood weight? (Max The Amazing)
how much does the turbo setup weigh? probably wont feel a difference.. since your adding hp.
Old Mar 11, 2007 | 09:18 PM
tcgordy's Avatar
whats up man, i just shipped my k20 turbo kit off with everything included to hook up and it weighed 75.6 lbs so around there, it wast a large intercooler per say, and the turbo (cybernation kit) was say same size as a 20G. ***** heavy.
Old Mar 11, 2007 | 09:31 PM
pandarex's Avatar
Default Re: (tcgordy)
my vis is about 14 pounds while my stock is around 30. i dont know specifics but about half
Old Mar 11, 2007 | 09:39 PM
grog's Avatar
I believe some hoods are a single layer, and some have 2 layers like a stock hood btw
Old Mar 11, 2007 | 09:49 PM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whole9 &raquo;</TD></TR><TR><TD CLASS="quote">How much weight would I save? 30 lbs maybe? thanks</TD></TR></TABLE>
I'm pretty sure the only way you could save 30lbs is by running with no hood at all . . .
The entire stock hood with latch, weatherstripping, insulation, emblem, and squirters barely weighs over 30lbs. 35 at most.
It also depends on which carbon fiber hood you're looking at. Some are much heavier than others.
15-20lbs is a more realistic number for weight savings.
Old Mar 11, 2007 | 09:56 PM
89civicdx's Avatar
Default Re: stock hood weight vs. carbon fiber hood weight? (Targa250R)
How much does a carbon hood weigh? My fiberglass hood weighed 12lbs
Old Mar 13, 2007 | 04:15 PM
carbonall's Avatar
* B A N N E D *
usually fiberglass hoods weight less then carbon. About 99% off all the hoods out there are overlayed carbon. Meaning they make a fiberglass hood then overlay it with carbon.
Old Mar 13, 2007 | 05:28 PM
JLefevers's Avatar
Default Re: (carbonall)
i always thought my oem hood did not weigh that much thats y i never really looked into a carbon or fiberglass hood also carbon and fiberglass fenders never understood it
Old Mar 13, 2007 | 06:06 PM
Crx Jimmy's Avatar
Default Re: (pandarex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pandarex &raquo;</TD></TR><TR><TD CLASS="quote">my vis is about 14 pounds while my stock is around 30. i dont know specifics but about half</TD></TR></TABLE>
I had similar measurements. My SIR VIS hood weighed 16lbs and the stock hood close to 30.
I dont know what kind of car you have but if you have a crx and want to drop a lot of weight for cheap get a hf bumper support its much lighter.
Old Mar 13, 2007 | 07:04 PM
JLefevers's Avatar
Default Re: (Crx Jimmy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">
I dont know what kind of car you have but if you have a crx and want to drop a lot of weight for cheap get a hf bumper support its much lighter.</TD></TR></TABLE>
Old Jun 18, 2007 | 01:16 AM
spaceman's Avatar
Default Re: (JLefevers)
whats the difference with the hf bumper support?
Old Jun 18, 2007 | 01:24 AM
HonDelso's Avatar
it made with less material to save weight. most of the weight saved on the HF is it's knuckles, bumper support, less sound dampening material. compared to it's DX counterpart.
Old Jun 18, 2007 | 01:51 AM
spaceman's Avatar
Default Re: (HonDelso)
hmm can you tell any difference in pictures? i wanna check that out.
also i'm looking forpeople who make fiberglass hoods for the crx..searching brings up lots of carbon fiber,but no fiberglass.
and one last thing.how do you think they made this hood? is it the stock hood with carbon fiber over it or something?
http://www.krazykustomzonline.....html
Old Jun 18, 2007 | 09:28 AM
highflyinhonda's Avatar
does anyone make a fiberglass SIR hood? Cant seem to find one.
Old Jun 18, 2007 | 09:33 AM
sitinthehall's Avatar
Default Re: (highflyinhonda)
stock = 30lbs
carbon fiber = around 15lbs
carbon kevlar = around 7.5lbs
Old Jun 18, 2007 | 09:35 AM
Default Re: (spaceman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spaceman &raquo;</TD></TR><TR><TD CLASS="quote">hmm can you tell any difference in pictures? i wanna check that out.
http://www.krazykustomzonline.....html</TD></TR></TABLE>
Carbon fiber molds are made by waxing a hood and making a mold of the hood. Its also possible to wax the hood, and directly lay the carbon fiber on the hood, using the hood as a mold.
Old Jun 18, 2007 | 10:31 AM
doublethink's Avatar
Fiberimages Carbon Fiber SiR Hood:
fourthgenhatchb17: OEM EF9 metal hood is 29.4 lbs
fourthgenhatchb17: EF9/8 of course
fourthgenhatchb17: FI weighed 13.8 lbs
fourthgenhatchb17: less than half
Larry's Kevlar one was about 2-3 lbs less then the others.
Depends on the quality of the workmanship involved and what type of underskeleton they use.
Thats 95% of the weight of this type of hood.
Old Jun 18, 2007 | 02:06 PM
spaceman's Avatar
Default Re: stock hood weight vs. carbon fiber hood weight? (doublethink)
anyone check out the link i posted? it looks like a stock hood with vents installed
anyone have pics of an hf bumper support?
Old Jun 18, 2007 | 02:13 PM
Default Re: stock hood weight vs. carbon fiber hood weight? (spaceman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spaceman &raquo;</TD></TR><TR><TD CLASS="quote">anyone check out the link i posted? it looks like a stock hood with vents installed
yea but its fiberglassed, and along the way they decided to make it an abomination of epic proportions.
i havn't seen anything that ugly since 1997, that was a serious blast from the past in terms of vomit/burp sensations.
Old Jun 18, 2007 | 02:39 PM
spaceman's Avatar
lol i wanna get it,but only if its all fiberglass and not a hacked up oem one.
anyone know if that thing is all fiberglass?
Old Jun 18, 2007 | 02:49 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spaceman &raquo;</TD></TR><TR><TD CLASS="quote">lol i wanna get it,but only if its all fiberglass and not a hacked up oem one.
you're aware you'll be forced to run full hoodpins, the factory latch cannot hold that flimsy thing down....
