Clutch wont disengauge...
Old Mar 10, 2007 | 09:59 PM
jay di em02's Avatar
Default Clutch wont disengauge...
My clutch wont disengauge, i put a new flywheel on, new clutch, throwout bearing, all that good stuff......i put the tranny back on and i aligned everything before so its all good, i adjusted the clutch cable so it grabs when u push the pedal down, it just wont move the car, the shift linkage works because it throws the reverse lights on...im pretty puzzled on what it might be but i really need some help asap....
thanks..
Old Mar 10, 2007 | 10:02 PM
garageEF's Avatar
Default Re: Clutch wont disengauge... (jay di em02)
its your clutch cable
Old Mar 10, 2007 | 10:04 PM
Default Re: Clutch wont disengauge... (garageEF)
well my clutch cable was adjusted out to where the pedal grabbed it, i can put it in any gear w/ out pushing in the clutch, and the car wont stall...
EDIT: ooops i meant my clutch wont engage....
its stuck disengauged..
Old Mar 10, 2007 | 10:23 PM
garageEF's Avatar
you can put it in any gear without the car stalling with the clutch out?
thats not even close to right. adjust it so that the clutch disk begins to grab when the pedal is two inches from the floor
Old Mar 10, 2007 | 10:41 PM
dohc_profile's Avatar
check your axles.. bet u one popped out.
Old Mar 10, 2007 | 10:47 PM
ef_zcvtec's Avatar
Default Re: (sohc_mnstr)
yep, ill put money on it the axles, check that ****
Old Mar 10, 2007 | 11:03 PM
before i do that, my dad said that he thinks the guy put the clutch on reversed.....
Old Mar 11, 2007 | 11:42 AM
today we pulled off the tranny again, we found that everything was on and installed properly, so we really dont know what it could be...any ideas?
Old Mar 11, 2007 | 01:48 PM
92civicfreak's Avatar
u gotta make sure everything is aligned properly, i know u said it was, but try to have the same distance around the "alignment tool" .... the tool doesn't align everything , it just helps to put the clutch on... b/4 u bolt down the whole assembly run ur finger around the alignment tool making sure that there is equal distance between the tool & the clutch....
1. if u try to start the car in neutral can u?
2. can u start the car in 1st w/ the clutch down?
3. can u start the car in 1st w/o the clutch?
Old Mar 11, 2007 | 02:41 PM
im gonna try that right now, do u think it could be the pressure plate though?
Old Mar 11, 2007 | 08:06 PM
possibly... i knew one kid in my auto trannies class didn't align the plate/clutch properly & his eclipse wouldn't start...
danno33
12
Sep 30, 2012 08:46 PM
danno33
Jul 14, 2009 07:45 AM
MichealSenior
Feb 17, 2009 12:56 AM
92TEGGYGSR
Jul 12, 2004 04:56 AM
Ataraxia
Jun 22, 2004 05:23 PM
