JDM center console question??
Old May 22, 2002 | 06:43 PM
comptechgsr2000
Guest
Posts: n/a
Default JDM center console question??
If you look at the bottom left side of the console, you will see a red line. If I get this piece will there be paint showing through? What I'm asking is will the JDM piece cover the metal bracket that our stock piece uses?
Thank you for your help.
Old May 22, 2002 | 06:44 PM
jdmspoonitr's Avatar
Default Re: JDM center console question?? (comptechgsr2000)
it should cover that part....they prolly messed up the carpet somehow....don't worry...the metal should not show if ur car is normal
Old May 22, 2002 | 06:50 PM
AssPenny's Avatar
Default Re: JDM center console question?? (jdmspoonitr)
The metal does show.. I've got one and it will show aslong as you got usdm carpet. That is where the usdm bracket goes through the carpet to hold the usdm center console
Old May 22, 2002 | 06:59 PM
done's Avatar
mine is exactly like that, shows to little strips, ill take a pic of it tomorrow, i think you can tuck it in, im not sure, i dont worrie about it, it really does help, i like the jdm console alot
Old May 22, 2002 | 07:11 PM
disordeR's Avatar
does the center console include those seats?!
Old May 22, 2002 | 07:17 PM
comptechgsr2000
Guest
Posts: n/a
Default Re: JDM center console question?? (AssPenny)
Thanks I thought so I took mine off and noticed the metal brackets
Driver's Avatar
Default Re: JDM center console question?? (Jordo)
shifting right ?
Old May 22, 2002 | 07:19 PM
comptechgsr2000
Guest
Posts: n/a
Default Re: JDM center console question?? (01-1214)
No I think the arm rest looks ugly.
Old May 22, 2002 | 07:22 PM
azn98R's Avatar
Where would your badge go
Old May 22, 2002 | 08:20 PM
comptechgsr2000
Guest
Posts: n/a
Default Re: JDM center console question?? (azn98R)
I still thinks its ugly
Old May 22, 2002 | 08:22 PM
fowler!'s Avatar
Don't they use that console because the JDM ITR seat bolsters rub on a stock armrest?
Old May 22, 2002 | 08:24 PM
comptechgsr2000
Guest
Posts: n/a
Default Re: JDM center console question?? (fowler)
What did you do with the metal brackets that stick out? Do you just cut them off?
Old May 22, 2002 | 08:34 PM
ithrowpoop's Avatar
The badge would go where the bolt cover goes. On a jdm type r that is where the badge is. To get the metal bracket off and get the new one on you need to unbold the two bolts holding on the e-brake cables.
Old May 22, 2002 | 08:37 PM
comptechgsr2000
Guest
Posts: n/a
Default Re: JDM center console question?? (BY2KGSR)
Thank you
Old May 22, 2002 | 08:39 PM
JL 74's Avatar
so where will you keep the contrabands with the jdm console? jk
Old May 22, 2002 | 08:52 PM
Mike M's Avatar
Founding Member
Default Re: JDM center console question?? (jl74)
JDM Roof Console J/K
A Quick Fix to close up the open carpet areas from the USDM Console is to go to a carpet store and ask if they have two small strips of that stuff they use to join to abutting carpets (Normally they will have some scrap pieces)
I don't know the name for it but it looks like a piece of thin carboard paper with a glue on it. You put it under the carpet and use this tool that they have that warms it through the carpet and the patch adheres the back of the two pieces of carpet together as one.
Old May 22, 2002 | 08:54 PM
comptechgsr2000
Guest
Posts: n/a
Default Re: JDM center console question?? (TypeRmsm)
God Bless you Mike!
ef-hatchcrap
15
Jan 25, 2007 01:38 PM
SLR SKiLLZ
Nov 15, 2004 04:06 PM
bartek_b
Aug 3, 2003 10:03 AM
Flux
Jun 23, 2002 10:44 AM
