can i use this
Old Mar 10, 2007 | 05:35 PM
demonicivis1320's Avatar
Default can i use this
can i use a pr4 in my dx wit mpfi swap on a sohc
Old Mar 10, 2007 | 05:54 PM
beatthisspeed69's Avatar
yeah bcuz i had a pr4 in my sohc
Old Mar 10, 2007 | 05:55 PM
garageEF's Avatar
Default Re: can i use this (demonicivis1320)
as long as its a obd0 mpfi ecu you can use it.
Old Mar 10, 2007 | 06:03 PM
Default Re: can i use this (garageEF)
well i'm giting some codes 14 4 and 9 wtf
Old Mar 10, 2007 | 06:13 PM
garageEF's Avatar
is your car an 88?
Old Mar 10, 2007 | 06:31 PM
no a 91 hatch
Old Mar 10, 2007 | 06:34 PM
garageEF's Avatar
did you look up the codes? i dont know them off the top of my head. list them and ill try to help more.
Old Mar 10, 2007 | 06:38 PM
i'm giting 49 and 14
1 O2A - Oxygen sensor #1
2 O2B - Oxygen sensor #2
3 MAP - manifold absolute pressure sensor
4 CKP - crank position sensor
5 MAP - manifold absolute pressure sensor
6 ECT - water temperature sensor
7 TPS - throttle position sensor
8 TDC - top dead centre sensor
9 CYP - cylinder sensor
10 IAT - intake air temperature sensor
12 EGR - exhaust gas recirculation lift valve
13 BARO - atmospheric pressure sensor
14 IAC (EACV) - idle air control valve
15 Ignition output signal
16 Fuel injectors
17 VSS - speed sensor
19 Automatic transmission lockup control valve
20 Electrical load detector
21 VTEC spool solenoid valve
22 VTEC pressure valve
23 Knock sensor
30 Automatic transmission A signal
31 Automatic transmission B signal
36 traction control found on JDM ecu's
41 Primary oxygen sensor heater
43 Fuel supply system
45 Fuel system too rich or lean
48 LAF - lean air fuel sensor
54 CKF - crank fluctuation sensor
58 TDC sensor #2
61 Primary oxygen sensor
63 Secondary oxygen sensor
65 Secondary oxygen sensor heater
71 random misfire cylinder 1
72 random misfire cylinder 2
73 random misfire cylinder 3
74 random misfire cylinder 4
Old Mar 10, 2007 | 08:02 PM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by demonicivis1320 &raquo;</TD></TR><TR><TD CLASS="quote">can i use a pr4 in my dx wit mpfi swap on a sohc</TD></TR></TABLE>
Yeah, you *can* use it, but it's the wrong ECU so it's going to cause problems . . . thus you *shouldn't.*
If you're running a pre-OBD MPFI SOHC non-VTEC D15 or D16, you should be running a PM6.
Codes 4 and 9 usually indicate a bad distributor base.
Old Mar 10, 2007 | 08:16 PM
Default Re: can i use this (Targa250R)
well i got a d15 out of a del sol
Old Mar 10, 2007 | 08:27 PM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by demonicivis1320 &raquo;</TD></TR><TR><TD CLASS="quote">well i got a d15 out of a del sol</TD></TR></TABLE>
So why are you running it with a PR4?
Old Mar 10, 2007 | 08:48 PM
its the only ecu i could het a hold of
Old Mar 10, 2007 | 08:55 PM
midget's Avatar
you should be gravy just troubleshoot codes
Old Mar 10, 2007 | 08:57 PM
midget's Avatar
Default Re: can i use this (midget)
i had a pr4 in my 91 rex with a d16y7 and it threw codes but ran like a rape ape
Old Mar 10, 2007 | 09:49 PM
well mine falls on its face
DA_Boy_626
Oct 3, 2007 06:50 PM
J4k3
16
Jun 22, 2006 08:25 AM
kantfadedisazn
38
Feb 13, 2006 10:07 AM
GreenMachineRex
Dec 24, 2004 04:56 PM
BLuDoHcReX
Apr 3, 2003 07:36 PM
