can any one help me out i have a 92 accord with a f22b1 and i cant get spark
Old Mar 10, 2007 | 05:08 PM
vtec92accord's Avatar
Default can any one help me out i have a 92 accord with a f22b1 and i cant get spark
i cant get fire and i put a f22b1 obd2 motor in my 92 accord ex i put the stock distributor on and i cant get fire can any one help me
Old Mar 10, 2007 | 05:52 PM
JDM_DC4_Fanatic's Avatar
Default Re: can any one help me out i have a 92 accord with a f22b1 and i cant get spark (vtec92accord)
is the coil hooked up? Did you convert it to internal coil? Is there power to the harness on the dizzy? are the spark plug wires all cracked and crappy?
Old Mar 11, 2007 | 12:31 PM
i bought brand new spark plugs and wires and no i didnt convert it to internal im using the old wiring harness and old dizzy what do i need to do i have a internal dizzy also but the external coil dizzy is off the old motor
Old Mar 12, 2007 | 10:31 AM
1baddturbosi's Avatar
yes check coil, and check timing belt, mine jumped and thus i got no spark. after replacing plugs, wires, and distributor.
Old Mar 12, 2007 | 03:09 PM
Default Re: can any one help me out i have a 92 accord with a f22b1 and i cant get spark (1baddturbosi)
you are mistaken. If the timing belt skips, you will still have spark, given that everything is working properly. The timing belt does just that, Times the engine. It makes sure that the valves are open when they are supposed to be, and closed when they are supposed to be. The timing belt has nothing to do with a no spark condition. What it will cause is a no START condition. If its not timed correctly, the spark may fire on the exhaust stroke, and it wont start.
Old Mar 12, 2007 | 05:21 PM
Default Re: can any one help me out i have a 92 accord with a f22b1 and i cant get spark (JDM_DC4_Fanatic)
well thats just what happened to my civic, the timing belt jumped and threw my timing off. i bought a new distributor, new plugs, sold my msd. took my vavle cover off and my timing marks were way off. after that i got spark and it fired right up. so it might not of been working properly. i just couldnt get spark for the life of me.
id have to say check your external coil
Old Mar 12, 2007 | 05:56 PM
okay i got fire and i still am not getting it to start i tried everything i got a new dizzy new plugs and wires still wont start
Old Mar 12, 2007 | 06:01 PM
when my 92 accord didnt start last summer, i was told to replace the main-relay under the dash, and it fired right up. accords are prone for this relay going out. check to see if your getting fuel.
Old Mar 13, 2007 | 06:26 PM
thanks for your help i got it running finally
e-roc88
Nov 1, 2010 03:39 PM
lina sok
Mar 20, 2009 09:30 PM
PhilipK
Sep 21, 2007 12:43 PM
Dropped90Integra
Jan 21, 2006 09:24 AM
rpv173
Jul 24, 2005 09:15 AM
