CD PLAYER WONT TURN OFF!!!!!
I just put a cd player in today, checked the wiring and everything looks in order. But the problem is when the face plate is connected, with or without the keys in the ignition the cd player turns on and wotn turn off until I take the faceplate off.
The car is garaged at the moment so I went to check up a little over a week later, and the car was dead even with the faceplate disconnected.
Help or suggestions would be awsome.
Possibly....I honestly dont know, I just matches the harness colors to it and put it together. How do I know which wire is the remot, because I dont even use it anyway,.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 »</TD></TR><TR><TD CLASS="quote">^^ By "remote", do you mean accessory? Sounds like he's got the red & yellow wires hooked to the same constant 12v source... </TD></TR></TABLE>
Yeahp that is what i meant.
OP you might want to check that. could cause your problem.
Oregon
Audio / Security / Video
May 9, 2006 07:38 PM
Mike banX
Oct 28, 2003 06:59 PM
94
