oil pressure question
Old Mar 10, 2007 | 03:40 PM
motrayEG6's Avatar
Default oil pressure question
my buddy is rebuilding his gsr head and he is not getting any oil pressure any help would be great pm me or post thanks
the only thing i know is that he did use a ls head gasket everything else is stock
Old Mar 10, 2007 | 03:42 PM
Syndacate's Avatar
Default Re: oil pressure question (motrayEG6)
Uhh...any more info? What's aftermarket on it? What did he change? Was it working before?
Old Mar 10, 2007 | 03:43 PM
Projekt_2nr's Avatar
how old is the motor? make sure everything was properly installed yo
Old Mar 10, 2007 | 03:52 PM
motrayEG6's Avatar
nothing is aftermarket except for pistons are from a type r and the motor only has like 60-80k on it. and it was working before yes
Old Mar 10, 2007 | 03:56 PM
motrayEG6's Avatar
it actually only has about 20 minutes of running time the block and **** was sent out and completely cleaned and decked and he said that he put in like 5 1/2 quarts of oil in and it is still reading low on the dipstick
Old Mar 10, 2007 | 04:13 PM
motrayEG6's Avatar
need help badly
also there are no leaks anywhere
Old Mar 10, 2007 | 04:19 PM
Luserkid's Avatar
Default Re: (motrayEG6)
low on the dipstick doesnt tell you much on oil pressure. Does he have an oil pressure gauge?
Old Mar 10, 2007 | 04:21 PM
motrayEG6's Avatar
no its completely bone stock
my buddy said that he took off the valve cover and it was not squirting oil onto the cams and the top of the head
Modified by motrayEG6 at 7:53 PM 3/10/2007
Old Mar 10, 2007 | 04:56 PM
Luserkid's Avatar
Change the oil pump then.
Old Mar 10, 2007 | 07:54 PM
motrayEG6's Avatar
its brand new oem
Old Mar 10, 2007 | 07:58 PM
envee's Avatar
still possible it is junk. get a guage if it read pressure coming from the block then you got a new level of problem.
Modified by envee at 3:02 AM 3/12/2007
Old Mar 11, 2007 | 07:01 AM
motrayEG6's Avatar
even though he did send it away to get repolished and decked and **** it still could be junk?
Old Mar 11, 2007 | 11:03 PM
envee's Avatar
Could be something the shop did.
Could be a bad pump from factory.
Old Mar 12, 2007 | 09:09 PM
motrayEG6's Avatar
if any of u want to know what it was it was the ls head gasket
reddcoupe
May 14, 2012 08:14 AM
BLB
Mar 29, 2009 03:59 PM
Mashimaro
Jan 20, 2009 09:06 AM
sirwags
Jul 31, 2005 07:13 PM
importboi22
Oct 2, 2004 08:39 PM
