Finally got my car dynoed right.
Old Mar 10, 2007 | 03:00 PM
Lonnie's Avatar
Default Finally got my car dynoed right.
Old Mar 10, 2007 | 03:04 PM
VtecCarHauler's Avatar
Default Re: Finally got my car dynoed right. (Lonnie)
what's the set-up. Glad everything went ok for you.
Old Mar 10, 2007 | 03:07 PM
Lonnie's Avatar
Default Re: Finally got my car dynoed right. (VtecCarHauler)
Sleeved darton block 84.5 mm
ported b16 head
Gt4067 non bb
Old Mar 10, 2007 | 03:53 PM
good work!
Old Mar 10, 2007 | 04:35 PM
Jtuned DC2's Avatar
* B A N N E D *
Sick!
Old Mar 10, 2007 | 04:48 PM
A.E Motoring's Avatar
Default Re: (KevLo)
good numbers
Old Mar 10, 2007 | 05:22 PM
sewell94's Avatar
Default Re: (Dual Cam Racing)
Glad to see its back up and making some hp
Old Mar 10, 2007 | 06:08 PM
dome's Avatar
Default Re: (sewell94)
what cams , abd how much boost was that
Old Mar 10, 2007 | 06:30 PM
alpha's Avatar
What wastegate, exhaust manifold and turbine wheel? Bit of boost creep. Congrats!
Old Mar 10, 2007 | 09:19 PM
Lonnie's Avatar
Default Re: Finally got my car dynoed right. (alpha)
SET UP is
Sleeved gsr block
CP 9.8:1
Crower rods
Mild Ported B16 head
Tial 44 gate
Rev valves springs and retainers
STOCK GSR cams
Custom made top mount mani (Thanks Tony)
GT 4067 Non BB
3 inch down pipe and exhaust
27 ish psi of boost ( did spike a little at the end)
Old Mar 10, 2007 | 09:57 PM
GSaura's Avatar
Damn! That valve cover is awesome! Good numbers, too. you've put together quite a nice setup
Old Mar 11, 2007 | 08:06 AM
boosted k20's Avatar
Default Re: Finally got my car dynoed right. (GSaura)
whats ur fuel setup. looks like ur run n outta fuel
Old Mar 11, 2007 | 08:28 AM
SOHC_MShue's Avatar
nice numbers and that engine bay looks sexy
Old Mar 11, 2007 | 10:41 AM
Lonnie's Avatar
Default Re: Finally got my car dynoed right. (boosted k20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted k20 &raquo;</TD></TR><TR><TD CLASS="quote">whats ur fuel setup. looks like ur run n outta fuel</TD></TR></TABLE>
Weldon pump
Precision 1000 cc
No where close to running out of fuel yet
Old Mar 12, 2007 | 06:11 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lonnie &raquo;</TD></TR><TR><TD CLASS="quote">
Weldon pump
Precision 1000 cc
No where close to running out of fuel yet</TD></TR></TABLE>
frp, the a/f curve, looks like u need some more fuel. that graph was from a boost spike right? i hope the tuner added more fuel in the upper rpms and higher boost
clean setup btw
Old Mar 12, 2007 | 09:19 PM
Lonnie's Avatar
Yes there was a boost spike at the end and yes he did add more fuel there.
Old Mar 13, 2007 | 12:37 AM
RIP V8s's Avatar
pix of whole car? nice...
Old Mar 13, 2007 | 03:01 AM
93supercoupe's Avatar
Default Re: Finally got my car dynoed right. (b20vrex)
what was the final RPM, if its not posted?
Old Mar 13, 2007 | 03:12 AM
Topdawgg's Avatar
badass numbers...
Cant wait to get my setup done...
what is your fuel setup like?
Old Mar 13, 2007 | 05:52 AM
Turbocivic94's Avatar
Default Re: (Topdawgg)
nice setup and good numbers
I cant wait to see what GT4067 would do on around 38 psi
Old Mar 25, 2007 | 04:23 AM
Lonnie's Avatar
Default Re: (Turbocivic94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbocivic94 &raquo;</TD></TR><TR><TD CLASS="quote">nice setup and good numbers
I cant wait to see what GT4067 would do on around 38 psi</TD></TR></TABLE>
Heading back to the dyno this Fri with the 4 inch and more boost, so we will se what it does.
Old Mar 25, 2007 | 06:10 AM
nonvtecallmotor's Avatar
Default Re: (Lonnie)
Old Mar 30, 2007 | 06:39 AM
t<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lonnie &raquo;</TD></TR><TR><TD CLASS="quote">
Heading back to the dyno this Fri with the 4 inch and more boost, so we will se what it does.</TD></TR></TABLE>
That's what my car needed. 4inch is a must when u reach 500whp+
Old Mar 30, 2007 | 06:50 AM
silvrsled's Avatar
Default Re: (VtecCarHauler)
Wow, those are some nice numbers.
Old Mar 30, 2007 | 06:53 AM
juda7's Avatar
Good Stuff
