anyone know any place near Decatur, IL that would install a DOHC ZC in a CRX?
Old Mar 10, 2007 | 02:17 PM
drock4688's Avatar
Default anyone know any place near Decatur, IL that would install a DOHC ZC in a CRX?
i need the engine in and i have no way to get it to the chicago area, all the ones ive seen have been in the chicago area, i need one as close as possible but still a good place.
also i have a friend who is a mechanic that said he would install the engine for me, i am just worried because he is a domestic guy. I know hes capable i just need like a checklist so that everything that needs to get done gets done. basically i need the engine in and i need it soon and im on a tight budget, i need to know anything you guys can tell me about dohc zc's in crx's and how hard it is compared to other swaps.
Thank you in advance im sorry for rambling...alot of questions in one post too
Old Mar 10, 2007 | 02:19 PM
drock4688's Avatar
Default Re: anyone know any place near Decatur, IL that would install a DOHC ZC in a CRX? (drock4688)
btw my car is in my sig.
Old Mar 10, 2007 | 06:29 PM
drock4688's Avatar
anyone with DOHC ZC CRX swap knowlege please inform me
Old Mar 10, 2007 | 06:40 PM
CRXDrew's Avatar
Piece of cake... I'm in Champaign for school. When do you need it done?
Old Mar 10, 2007 | 10:11 PM
jpciii's Avatar
that swap is pretty much plug and play. It drops right in with minimal mods needed.
Old Mar 10, 2007 | 10:31 PM
njn63's Avatar
Default Re: (jpciii)
i'd be able do it the week of the 23rd and i'm in the Kankakee area. My rates are cheap.
Modified by njn63 at 1:43 AM 3/11/2007
Old Mar 11, 2007 | 07:14 AM
drock4688's Avatar
what exactly are the mods needed, i know i can use my ecu what about wiring harness...
Old Mar 11, 2007 | 07:53 AM
sikefcrx89's Avatar
Loved
Default Re: (drock4688)
depends on what model ef if its a hf or si just the distributor wiring needs modified and you can use you trans and axels.. other than that it bolts right in..
Old Mar 11, 2007 | 08:07 AM
drock4688's Avatar
Default Re: (sikefcrx89)
i have an si, i can use my wiring harness? and all i have to change is dist. wiring?
Old Mar 11, 2007 | 10:38 AM
sikefcrx89's Avatar
Loved
yes just mod the distrbutor wiring and youll be good for more info about this swap check out http://www.thezcr.com an use the search there.. it will answer all your questions
Old Mar 11, 2007 | 03:08 PM
drock4688's Avatar
so then i need a new tranny cuz my si one is messed up....is it cheaper to buy a tranny or to get axels?
Old Mar 11, 2007 | 06:00 PM
drock4688's Avatar
actually i donno if its the tranny, i got a new clutch put in and now it wont go into gear after i drive for like 5 min...its not the cable, i got a new one problem is the same...when i got my car it was fine it just slipped...thats why i got a new clutch...
does that sound like a tranny problem? or a clutch assembly problem?
Old Mar 12, 2007 | 06:13 PM
CRXDrew's Avatar
you get oil on the clutch?
Old Mar 12, 2007 | 06:49 PM
jpciii's Avatar
sounds like your new clutch wasn't installed right
Old Mar 12, 2007 | 08:59 PM
drock4688's Avatar
ok...so i should get the clutch looked at before i get a different one...thanks for all your help guys
Old Mar 12, 2007 | 09:11 PM
N1ghtM0nkey's Avatar
I'm in Danville, I could possibly stop by and help.
Old Mar 13, 2007 | 03:24 AM
GarageAlchemist
Guest
Posts: n/a
Default Re: (N1ghtM0nkey)
you guys should make a minimeet, get this kid some dohc zc powar..
Old Mar 13, 2007 | 08:33 AM
wiZCo's Avatar
Stouts 'n' Scotch
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jpciii &raquo;</TD></TR><TR><TD CLASS="quote">that swap is pretty much plug and play. It drops right in with minimal mods needed.</TD></TR></TABLE>
x2 I did it with a friend three years ago when I had very little automotive experience. It actually was easier than I expected.
Old Mar 13, 2007 | 08:56 AM
MagnaniEG6's Avatar
Default Re: (wiZCo)
I did the swap before its simple, if you need help let me know.
Old Mar 13, 2007 | 12:30 PM
drock4688's Avatar
Default Re: (MagnaniEG6)
thanks guys for all the help
does 100 sound like a good deal for a 88 si tranny? because if i need one i found one on here for 100...
also will it make a difference if the tranny is a diff year than the zc? or than my si ecu? jw
cuz now i have a 91 si ecu and im not sure what year the zc will be cuz i haven't ordered it yet, just trying to get this all set straight.
thanks again
Old Mar 13, 2007 | 12:36 PM
MagnaniEG6's Avatar
btw where are you order the motor do you have PM functions yet?
Old Mar 13, 2007 | 12:45 PM
xotic_crx's Avatar
I think the 88 tranny's have a different spline count than the 91's, dont they?
MagnaniEG6's Avatar
I sent you an email
Old Mar 13, 2007 | 12:49 PM
wiZCo's Avatar
Stouts 'n' Scotch
The transmission won't work unless you change your flywheel/clutch to an 88 as well. The ECU will work just fine regardless of the year.
Old Mar 13, 2007 | 12:53 PM
MagnaniEG6's Avatar
Default Re: (wiZCo)
88? I used an 89 si flywheel for my swap
