b16 into ef hatch prob help!
Old Mar 10, 2007 | 01:37 PM
battleREADYb20's Avatar
Default b16 into ef hatch prob help!
ok. i jus finished the swap .b16 into 91 si hatch. put new axles in and everything. when i got to drive it. it starts like shaking? it never did this with the stock motor in. when i put it in gear and drive it kinda chatters then its a shitty filling ride when driving. could someting be rubbing? its a j1 tranny im not sure if its lsd or not. lmk thanks and im using 90-93 integra axles no abs
Old Mar 10, 2007 | 01:39 PM
garageEF's Avatar
Default Re: b16 into ef hatch prob help! (battleREADYb20)
does it feel like its the clutch? you could have installed the cable wrong/not adjusted properly
Old Mar 10, 2007 | 02:09 PM
HxCforever's Avatar
what intermediate shaft and axles are you using? i ask because if you use a combination of jdm y1 intermedaite shaft and usdm 90-92 integra axles it will cuse the driver side to be an inch to long, & cause you axle to crimp. this made a really bad vibration on my hatch and a loud clunking noise.
Old Mar 10, 2007 | 03:29 PM
im not sure. its ajdm b16 from hmotorsonline. im guesiing the internidiate shaft its the jdmb16 and not the ls? im usingintegra axles 990-93 non abs. i jaced thje car up on stand let it run and it started doing it the clunking sound and look like the axles boots were cluttered up. my bro was saying it would have to be sometting with the intermidiate shaft or axles. are the axles boots supose to have some play. or be all piched up?
Old Mar 15, 2007 | 03:38 PM
HxCforever's Avatar
ok so i was right for the first time on honda-tech. your jdm intermediate shaft doesn't go smoothly with your usdm integra axles. you need to get a 90-93 integra intermedaite shaft part# is either sk5 or sk7 i cant seem to remember. then whala you problem is solved. i luckily found a guy localy with 2 ef9's and sold me the axles off of one.
Old Mar 15, 2007 | 04:45 PM
Bejita's Avatar
He has a J1 tranny so you're supposed to use 90-93 integra axles. You're axles are fine...Something else is FUBAR.
There were 3 kinds of intermediate shafts on first gen B16A's. It depends upon the tranny.
Old Mar 15, 2007 | 04:51 PM
Bejita's Avatar
This WILL answer all of your questions.
http://web.archive.org/web/200...s.htm
Old Mar 15, 2007 | 04:58 PM
crxpwr1's Avatar
Default Re: (Bejita)
he might need a front end alignment
Toe_fur
10
Jun 9, 2013 03:10 PM
philkehn
18
May 28, 2007 08:24 AM
highflyinhonda
12
Nov 15, 2006 12:10 PM
DukeVonDANK
Apr 20, 2005 02:27 PM
b16crx0062004
Nov 17, 2004 06:13 PM
