B16A3 into a '93 civic si
Old Mar 10, 2007 | 01:10 PM
Banjo the Ninja's Avatar
Default B16A3 into a '93 civic si
Ok, I've done some research and think I'm ready for another go at this...what would it take to get a b16a3 to run in my '93 civ si?
I have 2 d16's, their transmissions, one is vtec the other is not, but i have essentially everything that comes with them from harness to ecu. Will the harness I have work? Will I have to get a new ecu? If so, which one will I need? From what I understand it should be a fairly simple swap.
Old Mar 10, 2007 | 01:57 PM
em1mike's Avatar
Default Re: B16A3 into a '93 civic si (Banjo the Ninja)
dont go b16a3
b16a2 is more logical...
you do know b16a3 is from the DEL SLOW RIGHT?.....
Old Mar 10, 2007 | 01:59 PM
Eran's Avatar
HT White Ops
Default Re: B16A3 into a '93 civic si (em1boi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by em1boi &raquo;</TD></TR><TR><TD CLASS="quote">dont go b16a3
You know they're like, the same motor RIGHT?....
And that the B16A3 is OBD1, so it'll bolt right into a 92-95 civics with minimal wiring changes RIGHT?....
Old Mar 10, 2007 | 02:39 PM
bluebird's Avatar
</TD></TR></TABLE> WTF? so 160hp in a b16a3 is not as good as 160hp in a b16a2?
Everything from your si will work with the new motor... I believe you have to extend the 0xygen sensor plug a few inches though
Old Mar 10, 2007 | 02:46 PM
knockout's Avatar
dont make anymore stupid posts
b16a3 and b16a2's are practically the same thing, but OBD1 &gt; OBD2.
and you know that a Del Sol VTEC (aka the Del Slow) will stomp on your em1 pig of a car mod for mod right?
Old Mar 10, 2007 | 02:50 PM
Eran's Avatar
HT White Ops
Default Re: B16A3 into a '93 civic si (knockout)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by knockout &raquo;</TD></TR><TR><TD CLASS="quote">
and you know that a Del Sol VTEC (aka the Del Slow) will stomp on your em1 pig of a car mod for mod right?</TD></TR></TABLE>
How about you don't make anymore stupid posts either?
2000 Civic Si Curb Weight: 2601 lbs.
1997 Del Sol VTEC Curb Weight: 2522 lbs.
Oh yeah, those 79 lbs. are why EM1's run 15's and and Del Sol's run 9's ....
Old Mar 10, 2007 | 02:56 PM
em1mike's Avatar
Default Re: B16A3 into a '93 civic si (Eran)
9's lol ok..
Old Mar 10, 2007 | 02:57 PM
Eran's Avatar
HT White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by em1boi &raquo;</TD></TR><TR><TD CLASS="quote">9's lol ok.. </TD></TR></TABLE>
Apparently the concept of sarcasm escapes you. I was actually defending you against his retarded post ... not that your posts hold any more merit. They're both full of holes.
Old Mar 10, 2007 | 03:01 PM
knockout's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran &raquo;</TD></TR><TR><TD CLASS="quote">
Oh yeah, those 79 lbs. are why EM1's run 15's and and Del Sol's run 9's .... </TD></TR></TABLE>
Okay, so does the em1 weigh more than a del sol? Yes I believe it does.
Sure I exaggerated, big deal, it still weighs less.
Want to make the weight difference even further? Take of the Del Sol's ~10lb top off. (Im not sure if its eactly 10 pounds but Im sure a great google **** such as yourself will look it up for me in an attempt to prove me wrong so you can look cool on the internet.)
Old Mar 10, 2007 | 03:04 PM
Eran's Avatar
HT White Ops
Sure I exagurated, big deal, it still weighs less.
Want to make the weight difference even further? Take of the Del Sol's ~10lb top off. (Im not sure if its eactly 10 pounds but Im sure a great google **** such as yourself will look it up for me in an attempt to prove me wrong so you can look cool on the internet.)</TD></TR></TABLE>
Aren't you the kid that said a 99-00 Si exhaust manifold would fit on a 99-00 DX motor because they have the same front end?
Yeah, I thought so.
At a weight difference of 80lbs, the race will go to the better driver, not to the lighter vehicle. I don't look things up to look cool. I look up exact numbers to prevent the spread of misinformation like "del sols are super light" when in actuality, there are civic sedans that weigh less.
Old Mar 10, 2007 | 03:08 PM
knockout's Avatar
Yeah, I thought so.
At a weight difference of 80lbs, the race will go to the better driver, not to the lighter vehicle.</TD></TR></TABLE>
No go back and read it (i was under the impression he was saying he swapped a b16 in his dx and wanted to know if the si exhaust manifold would bolt up to his header back exhaust so if its different I misinterpreted it.), a dx + a b16 with a b16 header should bolt up to the exhaust since the front portion of the exhaust are the same.
and those 80 lbs will give the driver a .1 second room for error which is the difference in a good launch and a decent launch.
Old Mar 10, 2007 | 03:12 PM
Eran's Avatar
HT White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by knockout &raquo;</TD></TR><TR><TD CLASS="quote">No go back and read it (i was under the impression he was saying he swapped a b16 in his dx and wanted to know if the si exhaust manifold would bolt up to his header back exhaust so if its different I misinterpreted it.), a dx + a b16 with a b16 header should bolt up to the exhaust since the front portion of the exhaust are the same.</TD></TR></TABLE>
Considering he posted a DX manifold, I'm not sure what there was to misunderstand.
And 80lb's will give less than .08 seconds in perfect conditions with a perfect driver.
Old Mar 10, 2007 | 03:13 PM
em1mike's Avatar
Yeah, I thought so.</TD></TR></TABLE>
PWNED!
eran for president
Old Mar 10, 2007 | 03:14 PM
knockout's Avatar
And 80lb's will give less than .08 seconds in perfect conditions with a perfect driver.</TD></TR></TABLE>
He posted those pictures AFTER the fact.
Oh sorry, the **** strikes again!
Old Mar 10, 2007 | 03:19 PM
Eran's Avatar
HT White Ops
Oh sorry, the **** strikes again!</TD></TR></TABLE>
Being as you've called me a **** multiple times, I'm going to invoke Godwin's Law. This debate is now over.
http://en.wikipedia.org/wiki/Godwin%27s_law
Old Mar 10, 2007 | 03:33 PM
knockout's Avatar
Being that you've "invoked Godwin's Law" I'll have to reiterrate my point seeing as how youve used it as a distraction against my arguement. My basic arguement was, a del sol IS in fact lighter than an em1, am I right or wrong? exaggerations aside.
Old Mar 10, 2007 | 03:35 PM
em1mike's Avatar
randomest thread ive eva been in!
its about to get randomer
http://www.imagestation.com/album/?id=4290479995
https://honda-tech.com/zerothread?id=451467
^EUGENE FRM TRUE LIFE:IM A STREET RICER...EDIT-"racer"
Eran's Avatar
HT White Ops
Being that you've "invoked Godwin's Law" I'll have to reiterrate my point seeing as how youve used it as a distraction against my arguement. My basic arguement was, a del sol IS in fact lighter than an em1, am I right or wrong? exaggerations aside.</TD></TR></TABLE>
You are correct. But it's not enough to make a difference in your everyday life. Your argument was flawed from the beginning because you used such a gross exadgeration, and then proceeded to post incorrect numbers, more exaggerations, and then threw the '****' flag around. My argument was never that an EM1 was lighter than a Del Sol. My argument was against your original exadgeration.
Godwin's Law still stands.
Old Mar 10, 2007 | 03:40 PM
Syndacate's Avatar
And that the B16A3 is OBD1, so it'll bolt right into a 92-95 civics with minimal wiring changes RIGHT?....</TD></TR></TABLE>
Yeah I was thinking the same thing, OBD-I to OBD-I = FTW ...and they're the same motor .
Anyways...continue to round 3...
Old Mar 10, 2007 | 09:15 PM
Ok, wonderful, so my ECU, and wiring harness from the d16's should work fine for the b16? and yea I went with a3 over a2 because it's obdI, vs obdII, thanks much if what I'm reading aside from the petty arguments is correct
Old Mar 10, 2007 | 09:26 PM
Eran's Avatar
HT White Ops
Default Re: (Banjo the Ninja)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Banjo the Ninja &raquo;</TD></TR><TR><TD CLASS="quote">Ok, wonderful, so my ECU, and wiring harness from the d16's should work fine for the b16? and yea I went with a3 over a2 because it's obdI, vs obdII, thanks much if what I'm reading aside from the petty arguments is correct </TD></TR></TABLE>
No, your ecu will not work. You need the ecu for the B16A3, and a wiring harness from it would be a great help too.
Old Mar 10, 2007 | 10:02 PM
Default Re: (Eran)
Sorry for being such a tard, but would a spoon p28 chip work? what's the difference between the wiring harness i have and the b16a3?
Old Mar 10, 2007 | 10:03 PM
Eran's Avatar
HT White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Banjo the Ninja &raquo;</TD></TR><TR><TD CLASS="quote">Sorry for being such a tard, but would a spoon p28 chip work? what's the difference between the wiring harness i have and the b16a3?</TD></TR></TABLE>
Just use the stock ecu.
Old Mar 10, 2007 | 10:15 PM
cambopheonix56's Avatar
No those $20 ebay chips will not work.
Old Mar 10, 2007 | 10:17 PM
Default Re: (cambopheonix56)
kk...think I've almost got this, haha, I really appreciate all the help guys. So I'll need the b16a3, stock ecu, and wiring harness, everything else should be interchangeable, correct?
As a side note, I had bought a high output alternator for my civic, that should transfer without any problems, am I right?
