So my Miller Maxstar crapped out on me today...
Old Mar 10, 2007 | 11:54 AM
*Boostwerks*'s Avatar
Default So my Miller Maxstar crapped out on me today...
It was welding just fine, but when I was ready to weld up my next runner, it just wouldn't start an arc. It didn't overheat, or do anything unusual. It sputters kinda like I need to sharpen the tungesten, but it does the same even with a brand new tungsten.
Thank god for the 3 year warranty I guess.
Old Mar 10, 2007 | 01:50 PM
CSaddict's Avatar
Hows the ground clap.
Old Mar 10, 2007 | 02:41 PM
Default Re: (CSaddict)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CSaddict &raquo;</TD></TR><TR><TD CLASS="quote">Hows the ground clap.</TD></TR></TABLE>
clamps just fine.
Old Mar 10, 2007 | 07:47 PM
Lamchop0000's Avatar
Default Re: So my Miller Maxstar crapped out on me today... (Boostwerks.com)
twist those dinse connectors tight? check to see if the screw on dinse connector has backed out, if you have that type...
good luck
Old Mar 11, 2007 | 07:56 AM
Default Re: So my Miller Maxstar crapped out on me today... (Lamchop0000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lamchop0000 &raquo;</TD></TR><TR><TD CLASS="quote">twist those dinse connectors tight? check to see if the screw on dinse connector has backed out, if you have that type...
good luck</TD></TR></TABLE>
Yup their tight. I've checked everything, so I'm pretty sure something is up with the welder itself, especially because it just suddenly crapped out.
Old Mar 11, 2007 | 11:15 AM
RCautoworks's Avatar
Any leaks in the lines ?
Old Mar 11, 2007 | 05:00 PM
CRMB's Avatar
OG Fabricator
We had a similiar issue with a dyn 300dx --- it was the pedal. Just swap one out to test.
Old Mar 11, 2007 | 05:06 PM
Default Re: So my Miller Maxstar crapped out on me today... (RCautoworks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RCautoworks &raquo;</TD></TR><TR><TD CLASS="quote">Any leaks in the lines ? </TD></TR></TABLE>
Nope.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Racing-Solutions &raquo;</TD></TR><TR><TD CLASS="quote">We had a similiar issue with a dyn 300dx --- it was the pedal. Just swap one out to test.
o really? I have the finger tip control that came with it, so I'll give that a shot.
Old Mar 12, 2007 | 04:37 AM
Howitt's Avatar
check the breaker Ive had the half go before and check yourcord make sure its plugged it. I had a issue with my lincoln 275 called them fewdays later it was fixed warrantys are a +
Old Mar 13, 2007 | 02:14 PM
Default Re: So my Miller Maxstar crapped out on me today... (Howitt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Howitt &raquo;</TD></TR><TR><TD CLASS="quote">check the breaker Ive had the half go before and check yourcord make sure its plugged it. I had a issue with my lincoln 275 called them fewdays later it was fixed warrantys are a +</TD></TR></TABLE>
The breaker's fine, and all the cords were fine. I was running out of time to take it in, so I just dropped it off last night. I'll find out soon enough what's wrong.
Old Mar 23, 2007 | 07:54 PM
FINALLY...I was able to pick up my welder today. Apparently the PC board was fried.
Thank god for the 3 year warranty though. I'm sure this would have been a costly repair
silentdaredevil2
Welding / Fabrication
52
Jul 3, 2006 10:11 PM
accordinglyevil
Jun 23, 2006 12:32 AM
Ross
Honda Motorcycles
95
Apr 3, 2006 05:18 AM
Catch 22
27
Jul 2, 2003 05:57 AM
