What pillar bar do I need????
I have a 93 Eg. I wanna know what Pillar bar I need to use, for the headrest. I've been told the C pillar off an EG will do, but i've, also been told the C pillar off an Rsx is the one to use. Which is the one I need? Thanks in advance.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Super Trooper »</TD></TR><TR><TD CLASS="quote">But will it reach. I think the one I need is a little longer.</TD></TR></TABLE>
You need a harness bar. What you're trying to do is use a c-pillar bar as a b-pillar bar.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Super Trooper »</TD></TR><TR><TD CLASS="quote">I think its the B pillar bar if im not mistaken.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Super Trooper »</TD></TR><TR><TD CLASS="quote">I have a 93 Eg. I wanna know what Pillar bar I need to use, for the headrest. I've been told the C pillar off an EG will do, but i've, also been told the C pillar off an Rsx is the one to use. Which is the one I need? Thanks in advance.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Super Trooper »</TD></TR><TR><TD CLASS="quote">Yea. So will the C pillar bar work?</TD></TR></TABLE>
I don't know, I don't rig a part from one part of a car to fit another part of a car.
Harness are suppose to be used with a roll cage. If anything get a harness bar (i think heel toe sells one, or jdmshit), do not ghetto fit a C pillar bar for this. Under an accident it could kill you or make you paralized.
B Pillar bar is what you need. If you look at where the seatbelts are mounted to, its not exactly as far back as needed to ride comfortably. The b pillar bar will roll behind the seats and then go straight across.
But yeah, don't use it with some harnesses, that's hella ghetto rigged.
canduvtec
May 27, 2013 06:22 AM
EricUSC
May 22, 2003 12:15 PM
