Rear passenger side caliper sticking on my hatch??
HELP! Rear passenger side caliper sticking on my hatch??
I just noticed this annoying problem today, I adjusted my e-brake handle and now I notice my rear passenger caliper SOMETIMES sticks. When I'm about to launch normally, I feel the right side holding back and sometimes it makes a weird noise, like if the e-brake was up. I already adjusted the e-brake handle to see if I tightened too hard but it wasn't that. Like I said sometimes it sticks and other times its fine. Any ideas? FYI I have a 93 CX with rear disk conversion.
Re: HELP! Rear passenger side caliper sticking on my hatch?? (EL Vap133)
If you know it isn't the cable being adjusted too tight, rebuild or replace the caliper. There is a handbrake mechanism in the rear caliper that is probably sticking.
Re: HELP! Rear passenger side caliper sticking on my hatch?? (BubblegumTate)
Check the caliper, check the ebrake mechanism behind the caliper, check the cables, and check the equalizer.
Re: HELP! Rear passenger side caliper sticking on my hatch?? (93LShatchy)
Check to see if your caliper bracket sliding pins seized. There are 2 each on the rear. Remove them, clean out the bracket with some WD40 and a wire brush, remove the pins & clean with a wire wheel & grease up then test.
