Need Suggestions/Brake line related
Ok i have a d16z6 with a skunk 2 intake manfiold with str 68mm throttle body.
i have that known problem of the manifold hitting the brake prop valve. i put some poly motor mount inserts in the front and have one for the rear (not installed yet) and i have a lower profile bolt on the IAC to help.
all was well until i threw a CEL for TPS sensor...
aparently the IAC is no longer hitting the prop valve but the TPS is hitting a brake line coming from it.
i dont want to bend the brake line because thats only asking for trouble.
anyone have any suggestions for keeping it from hitting it? or a way to safely move that brake line, or the whole brake prop valve if needed?
thanks for any help, if any can be had
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus »</TD></TR><TR><TD CLASS="quote">If it's a known problem, there are bound to be known solutions.</TD></TR></TABLE>
there is a known solution to the bolt on the iac hitting, which ive already fixed.
however, i havent found an issue of the tps sensor hitting the brake lines yet.
someone did pm me and told me to just bend a little of the line, which i did, and i added a shim/washer to the prop mounting bracket (bottom one) and it moved everything back.
seems to be working ok for now.
JDM_WHR
May 27, 2013 05:27 PM
