Automatic radiator transmission lines to cool turbocharger??
Old Mar 10, 2007 | 08:21 AM
vtec.dc2's Avatar
Default Automatic radiator transmission lines to cool turbocharger??
Would it work to use transmission oil line fittings from automatic radiator for return/feed line for turbochrager water lines? in other words.. just run coolant through there on 5 speed that is..
why? some ebay radiators come with these fittings whether automatic or 5 speed.. was wondering if that would work or not.
Old Mar 10, 2007 | 08:27 AM
95jeremie's Avatar
Default Re: Automatic radiator transmission lines to cool turbocharger?? (vtec.dc2)
so you want to use the auto radiator in a manual and use the transmission fluid cooler section of the radiator to run coolant for your turbo?
Old Mar 10, 2007 | 08:54 AM
shortyz21's Avatar
u need a pump...
i dont see why it wouldnt work, but why the hell would u want that complex ****.. just hook it up to existing coolant lines
Old Mar 10, 2007 | 09:05 AM
95jeremie's Avatar
Default Re: Automatic radiator transmission lines to cool turbocharger?? (shortyz21)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shortyz21 &raquo;</TD></TR><TR><TD CLASS="quote">u need a pump...</TD></TR></TABLE>
That is what i was getting at i just wanted to make sure what he was talking about.
So yes you would need a pump. Just tap your existing coolant lines
Old Mar 10, 2007 | 12:04 PM
nateg's Avatar
no i think he wants to use the cooling section of the rad to pre cool the oil befor the turbo not a bad idea too bad i run a fluidyne otherwhise i'd try it
Old Mar 10, 2007 | 08:19 PM
vtec.dc2's Avatar
Default Re: Automatic radiator transmission lines to cool turbocharger?? (nateg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nateg &raquo;</TD></TR><TR><TD CLASS="quote">no i think he wants to use the cooling section of the rad to pre cool the oil befor the turbo not a bad idea too bad i run a fluidyne otherwhise i'd try it</TD></TR></TABLE>
no, not for oil.. for coolant.. just thought it might work but now i see what could be the problem (nothing to rotate it)
Hemix
Feb 5, 2010 01:30 PM
hondastudent1on1
Sep 9, 2009 03:58 AM
about:blank
Jun 27, 2008 05:27 PM
Briang3a3
Jan 17, 2008 10:57 AM
robbbby
Welding / Fabrication
Dec 4, 2007 09:39 PM
